New mobo/RAM/CPU, no power?
sircuddles
I just installed an Asus P8P67 LE with a 2500K and 2x4GB DDR1600 (XMS) and a Arctic Cooler Freezer 13. Old system was an AMD x3 720, DDR2. PSU is an Antec 650W, 2x74GB Raptors and a 1TB on SATA. GTX 580, IDE CD drive.
I uninstalled the mobo and installed the Asus along with the CPU, HSF and RAM. I then plugged all the power connectors back in (only things I unplugged are what went to the mobo), GTX shows green lights. When I press power, nothing happens at all.
The only problem I can see is that my PSU has a 6 pin connector, and the mobo has an 8 pin. I have the 6 pin plugged in the only way it will fit. Do I need a new PSU, or is it possible something else is the culprit?
You might have plugged in the wrong plug into the EPS+12V socket. The 6-pin plug is for PCI-e graphics card power. Also, you most likely plugged in the wrong plug (the 8-pin plug is that EPS +12V plug that should have been plugged into the mobo instead) into one of the GTX 580's PCI-e power sockets.
After further inspection it looks like the 4 pin that I unplugged from my old mobo was tucked away, and somehow the GPU pin did get unplugged. I put the 4 pin in the 8 pin mobo slot and am sitting at the BIOS. Thanks.
