New mobo, old PSU - adaptor?
eggrock
I'm building a PC for my wife and picked up a mobo/cpu combo at the egg. The motherboard is a Biostar TForce 6100 and takes a 24-pin power connector. The PSU I have is an Antec 350W (SL350) with a 20-pin connector and an additional 4-pin connector.
Looking at the manuals for both I see the voltages on the pins for each are different. I see 20-to-24 pin adaptors; I'm wondering if that's a reasonable plan to get one. At a guess 350W will be enough to run this; it's a fairly minimal setup using onboard everything, a DVD player and a couple of HDDs.
Noob question - Do all 20-pin PSUs use the same configuration? Do all 24-pin motherboards do the same? (Assuming ATX in each case.) I'm guessing it's in the spec but I should make sure so I don't wind up sending +12V to RAM. Helluva overclock for a few nanoseconds if I did. ;)
Think that'll do me fine or do I need to shell out for another PSU?
I have 2 machines that are running just fine with 24>20 pin ATX connectors. Some manufacturers, like DFI, recommend against it, but I don't think you'll have any problem. It's cost you $5-$10.
Plug the twenty pin into the twenty four. It will leave 4 pins vacent, all on one side.
According to the manuals they still don't line up. The Antec manual references a bunch of "COM" pins--I don't know what those do. Also, the 4-pin connector has 2 +12V pins and 2 "COM" pins. I don't see any combination that will work.
I'll try the adaptor and see how it goes. Hopefully someone local carries these; my wife's on my ass to get her new desk cleaned up. :rolleyes: :D
OMG NO! Put the screwdriver down, step away from that computer and think.
The 4-pin is a seperate 4-pin and goes in a seperate 4-pin header that has NOTHING to do with whether your board has a 20 or 24-pin ATX header.
What Bbq is suggesting is putting the 20-pin off of the power supply in the 24-pin connector on the motherboard. It WILL line up. It WILL leave four pins on the side exposed and you DO NOT put your 2x2 connector in there to "compensate."
Breathe, jonny, breathe!
LOL First thing I looked at actually, but it was easy to see that that wouldn't be a good thing to do. Besides, the mobo has a 2x2 connector on it as well that matched up with the voltages.
The 24-pin adaptor is working fine, no problems.
Nice little mobo by the way.
I had my Asus A8N-SLI with its 24 pin connector hooked up to my 20pin FSP, and everything worked just fine. overclocked, too.
the 20-pin to 24-pin adapters are a crock.
I have been using just a 20-pin PSU with my Tforce6100 for awhile. It works fine. Just plug it in. Leave the TOP four pins open.
