new mobo/old hard drive
robmarti25
I am installing a new processor, mobo and video card but want to keep all my old data and HD (old raptor). What do I need to do before installing all the new components. Do i just delete all the drivers in add/remove software or is there more? thanks for the help
are you wanting to just add it as a secondary data hdd or run your OS of it as well?
If you are running XP, you can normally just do a repair install if it won't boot up with the new hardware - depending on how different it is from what you had before it mihgt/might not work. You can also use sysprep to force XP to find new drivers for everything - google Sysprep and see what you find.
Link to Arstechnica
The server is busy, but the short of it is before you build the new system, i.e. the last time you shut the PC down before rebuilding, uninstall as much of your hardware from the Hardware manager, and then change the drivers on you HD controllers to the basic MS drivers and then shut down, once you boot the new system you should be able to install all the new drivers with little to no problem, I've followed this method several times and it's worked flawlessly for me.
