NEW Mobile Athlon XP's?
Jeff
I was checking out prices on cpus and I happened to stumble across this.
http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-441&depa=1
First of all its a XPM+2000 with 512K cache. I thought that was strange because the only ones i seen before with 512k are the XPM2400, XPM2500, and XPM2600
And another thing about that link above. Check out the picture. It surely doesnt look like its for SocketA because of how big the packaging is compared to the core, unless amd went to a .22micron process or something.
Also, if you will notice all of the other XPM's that newegg is selling. All of them have 512kb cache. Even the lower end ones which used to be 256K.
Did I miss out on some kind of product change announcement? Or is this another one of AMD's "Quiet Launches"?
EDIT: Waiiiit a second..... That socket size seems incredibly similar to the size of a Socket754. Interesting.....do you think it could be one of the new cpus with the 32bit core for the socket 754?
Looks like AMD just quiet launched some more low end low power laptop chips. They are Socket A, and it doesn't look like there is any difference between them and the 35w 2200+ chips except for the clock speed. They proabably overclock ok, but not great, but the only way to find out is if someone tries them out.
Me thinks they are ClawHammer rejects. ClawHammer is the only core AMD made that rectangular... well, recently.
Newegg probably used the wrong picture for this chip.
If I was going to buy an XP-M I'd stick with the higher rated mobile chips personally. Better yields=better ratings=better overclockability.
Well, it is a good suggestion that they put the wrong image. Many online vendors make mistakes. However, what caught my eye was that the label on the CPU is the same as the label specified on the page. I compared the label on that XPM2000 to the XPM2500 and the only difference i could see was the 2500 instead of the 2000 and 2nd to the end it said FQ.
Someone buy the cpu and try it out :p
I'm wondering if Newegg might have mismarked those procs as socket A chips. AMD did come out with mobile procs that use a smaller socket than socket A, but I've never actually seen one of the procs supposed to fit that smaller mobile socket. Notice that the proc also doesn't have the 4 rubber cushions around the edges of the proc either.
what? barton cores are rectangular
That could be a micro-PGA chip, but I don't see that speed grade on AMD's site. If it is, it won't fit in a desktop board, but will fit in laptops (thin and light) that use the micro-PGA socket.
It does kind of look like the "lid-less" mobile Athlon 64 (micro-pga), so maybe they did just use the wrong picture.
biglove,6/23/2004 7:41:10 PM this is not a socket a chip it says it is but tryust me it isnt
thats what the reviewer on newegg said, granted he can't spell and his name is biglove but doshgarnit i trust him.
Ahh....i remember the name now. Sempr0n. Could that cpu in the pic possibly be a Sempr0n?
They are the AthlonXP core + enhancements? But is bolted onto a socket 754 packaging.
Something like that?
It looks very different, what caught my eye was the resistor(or whatever those surface mount things are) arrangement compared to regular mobiles. I don't think these are socket A.
