New Mini-ITX 1155 build
I have been following this for a while now and did released info about ST45SF's return rate back in March in another thread:
http://hardforum.com/showpost.php?p=1036928033&postcount=9
The return rate is still low and our tech support in Taiwan has not received e-mails about it since then. Statistically, the ST45SF is performing very well.
Mine wasn't really chirping. It was very much a clicking. I can get it to click on command though, I just have to run prime95 and the Crysis benchmark at the same time. I have the power supply mounted upside-down so that is sucks in fresh air from the outside. This also causes the clicking to be fairly easy to hear.
I'm not too worried about it, nothing I normally do will cause the clicking. Even running 3dMark11 on "extreme" mode does not cause it. I'm definitely not returning it unless it starts clicking in the games I normally play. So far I can run every game out there at 1920x1080 on very high with AA's and no clicking and smooth performance.
Sorry for posting in your thread 1legged_sheep but the info i ask may help others if provided so i see no reason to pm Tony Ou for this.
Ok. I see you are a silverstone rep, help me out abit then.
I live in Romania, and I can only find SG05 /w 300PSU here. I could order the 450W from e-bay germany no problem. Shipping is only 10euros so no biggie. But in case it chirps, i have to send it back in germany i suppose, and that I do not like.
Not to mention...describing the issue. Nvidia recommends a minimum 500W PSU for 560Ti so basically the seller could "wash his hands" on the matter.
Yes the SG05 /w 450W PSU is nicer because it's black painted inside. (no big deal i guess, a can of paint spray can fix things).
Now with the risk of being redundant, some people in this forum said that the 300W PSU could handle a 560ti and an i5 2500. I also found a site that sells a pre-assembled system with the same specs /w the 300W PSU. http://www.extremeware.de/product_info.php?products_id=88&XTCsid=007bf1b47b07ef58283736a1249b38b9
But since you are a rep, what is your opinion on this?
LE:
Just recieved a response e-mail from extremeware.de and it seems that the 300W PSU is enough.
At default speeds, the maximum power consumption for the 560TI and i5 2500 are 200W and 95W respectively. So if you are not planning on overclocking, the 300W PSU should just be sufficient, but it will be very close. I would recommend that you move up to 450W for a little bit more headroom.
So this afternoon I'm going to take a video of the power supply "clicking" and post it. It will give some of you who are curious a chance to see and hear it happen. I can get it to do it on command now, just run crysis and prime95 and it will start clicking. As soon as I shut off the Crysis benchmark it stops.
Tony, thanks for your replies it's good to see feedback from a manufacturer representative on a community.
I have a question about the SG05 and FT03. On both cases the front panel headers are noisy IF an USB header is connected to the motherboard.
It's a fact, not an isolated case since I sell PCs and use the SG05 as my mainstream offering. I contacted silverstone on the web site but...it was kinda annoying they saying I should RMA for a replacement when 11/11 of these cases have had that issue.
I didn't really care for myself but one of my customers did care and annoyed me till he got an USB headset.
Can you do me a huge favor??? Can you run geekbench and post your score pretty please!
both of you :)
fr500, could you please tell me what was the highest performance system you assembled in a SG05?
Not many lately so DFI MI-P55-T36 + i7 860 with a GTX460 on the 450w PSU. I don't want to push the envelope further on the PSU. If it starts chirping on my customers they will annoy me and I'd have to RMA which can get expensive when you are on Ecuador.
Might have 2 builds next week based on SB (crosses fingers)
