new MB for WHS
mobilecommand
Howdy,
i am looking to build a new WHS and i am having trouble selecting a MB with DDR 3. I dont exactly see windows 2003 drivers for them but it appears the xp drives should look fine.
i plan on adding in 2x of the supermicro 8 port jbod cards and maybe a intel gig nic depeding on the MB i may need to add in a pci video card as well.
let me know what you think.
thanks
ASUS M4A785TD-V EVO
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131398
ASUS M4A79XTD EVO - no on board video but 7 sata ports.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131402
GIGABYTE GA-MA790GPT-UD3H
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128398
MSI NF980-G65
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130236
scratch the NF980 for sure.. worthless motherboard..
stick with the 785g or 790GX(anything that starts with a G) since both will have onboard video which will mean that you can use the PCI-e x16/x8 lanes for raid/jbod sata cards instead of having to worry about how many ports come on the motherboard its self..
i am partial to the gigabyte UD series becuase they have solid caps. I have seen many video cards and motherboard's caps leak with in 4 years. ideally your WHS is going to last for at min 4 years without hardware changing.
so any of the asus and gigabyte will work but i like the UD series
both the asus boards are a nice choice. i have two friends running the 790x and there happy with them.
