new MB advice
dgingeri
I have been using AMD processors since the first Socket A chips came out. My last Intel system was a P3-450. With that said, you'll know I have had little experience with recent Intel systems.
Now, things are changing. I currently have a Athlon64 X2 4200+ and a dying motherboard. This is my secondary system, which acts as gateway, router, proxy. I need to replace it. I am planning on moving my current main system (MB, CPU, and RAM) to the secondary slot and invest in a main system upgrade. My current main is an Opteron 185 with 2GB of DDR400. The 8800GTX I have will stay as my main. I am planning on using on-board sound, since Creative can't make a stable sound card to save their lives. I am also currently running Vista x64.
I have decided to go ahead and get the Core 2 Duo E6850 CPU and 4GB of DDR2-800. I'm not really looking to overclock right now, but might in the future. I have looked over MB reviews, and am simply confused since none of them really make direct comparisons between boards and chipsets. I need a good, stable board with at least 1 PCI slot and would prefer to have a PCIe X4 or higher slot in addition to the main graphics card slot, for possible future RAID controller. I need at least 6 SATA ports, for my 2 Optical drives and 4 hard drives. I would prefer not to have serial and parallel ports, but if the best board has them, I guess I could live with that.
Any recommendations?
thirded.
Or a Gigabyte P35-DS3P/DS4/DQ6 or Asus P5K Premium if the IP35 Pro doesn't take your fancy.
Excellent. I hadn't even looked into the Abit board. That layout is nice. It looks like those caps are all solid, too. that's a plus. I googled it and found a couple other reviews. it reviews well. I have added it to my wishlist on newegg. As soon as my company's acquisition finishes and I get my bonus, I'll order it. Thanks a bunch.
thirded.
Yuppers. There are a lot of good p35 boards out there. If you are going with a single Nvidia card or a Crossfire setup get a p35. Also, DFI should have there unqiue p35 board coming out in a few weeks which is what I would wait for, as long as the results were good in the retail version.
However, if you are going SLI, get a 680i board.
Good luck man. Also, are you sure you want a 6850 over a q6600 ($300)? I'd rethink that man. Just my opinion.
I definitely don't want to go for a quad core just yet. Most programs don't use a dual core, quad core just seems like it would go to waste.
