New mATX Case: Silverstone PS08
http://www.silverstonetek.com/product.php?pid=352
Model No.
SST-PS08B (Black)
Material
High-strength plastic and meshed front panel
Motherboard
Micro-ATX, Mini-ITX
External 5.25" x 2
Internal 3.5" x 4, 2.5” x 1
Cooling System
Front 1 x 120mm intake fan, 1 x 80mm fan slot
Rear 1 x 80mm fan slot or 1 x 92mm fan slot
Expansion Slot
4
Front I/O Port
USB 3.0 x 2
Audio x 1
MIC x 1
Power Supply
1 x optional standard PS2(ATX)
Expansion Card
Compatible up to 14.1 inches in length
Limitation of CPU cooler
140mm
Limitation of PSU
Unlimited
Net Weight
3.46kg
Dimension
168mm (W) x 355mm (H) x 400mm (D), 23.85 liters
Extra
Support Kensington locks
Hmm, not liking this as much as the SG09, however they are for different purposes.
I don't like how the hdds cover up 24pin and looks like perhaps part of the ram.
Installation would be a little tough without being able to remove the hdd bay area.
For a moment I was thinking, hoping it might be a watercooling version of the SG09... oh well. Back to 2005 design: too many drive bays and 80/92mm case fans :)
No removeable HDD trays or rack :(
It's a pain trying to install, remove or replace drives when the MB and cables are in the way.
I guess I just don't see the point in this case with the SG09 just about to be available worldwide and all. It might be a good value-oriented object for people that dig oldschool tower aesthetics.
It's a a fully functional MATX case, probably under $60 and with decent cooling potential
The PS08 is not really targeted at people that would normally visit hardware forums, but since it's been brought up here. I'll provide a little bit more info:
- PS08 is smaller than it looks, at around 24 liters, it is 20% smaller than TJ08-E.
- It's inexpensive, the estimated street price should be well under $50.
- November availability.
A case that size and the rear fan is 92mm? Thats a fail IMO. SS couldn't fit a 120mm in there?
