Guys,
Got my new Neo2 Plat to post last night, and went through and hooked the 2 WD Raptors up to SATA 3/4 on the mobo but I keep hanging at the "Detecting RAID Array" step of boot.
BIOS sees the drives ok, and everything looks ok.
I had it working for a second, and started the XP Pro install. I got to the step where you F6, then give it the RAID drivers - after this it told me XP Setup had found a drive problem (or the drives were raw) and corrected it. Now I can't see the RAID BIOS at all, nor can I get back into XP setup.
My MSI Bios is V1.1, Running 2 sticks of OCZ dual channel plat rev2 in slots 1 and 2.
No other changes have been made in BIOS other than enabling SATA and the RAID functions.
Please help - I'm losing my mind here....
edit:
Just found that updating the bios to the latest revision on the mobo got me past this - new issue is that I see 2 partitions in XP setup. Is that ok?
edit2:
Now for some reason the machine shows 2 partitions: c: as a 138.48GB partition (active), and e: as a 69.23GB partition (System)
When I try to access C:, it says C:\ is not accessable. Drive manager shows it as 100% free space.
Please help. I'm dying here.
edit:
edit2:
