New Lian-Li case - PC-B25B
B25 = awesomeness
But I thought for sure it would go for under a $200 price point. It is however a very nice case and I could justify paying that. A little more justification than I would like.
I don't like the sideways mounted lower 3.25" harddrive rack. I've had bad experiences where it seems like those sideways ones block intake airflow much more than straight ones.
To compound that issue, clearance for normal SATA plugs is slim between harddrives and case panel. Have to dig around for those 90degree connectors.
I do like the extra intake 120mm fan though.
*thumbs down*
PC-7B > that IMHO
According to the Benchmark review - the drive cage can be rotated and mounted either way.
I personally like the side-facing HDs, but choice is good.
