New lag tester and clone timing issues
Yelnats
I made a very simple application for testing input lag.
It displays a white bar that is the height of the screen. The white bar moves to the right 50 pixels at each refresh, looping back to the beginning after 10 refreshes. There are also 10 white squares that are always on so you can compare position. Because LCD monitors update sequentially, from top to bottom, just like CRTs, you can compare them with sub frame accuracy.
I used the program to test my 2005FPW and my 2007WFP in clone mode. When I switched which DVI ports each monitor was connected to, I got different results. The port closer to the motherboard is faster. The 2007 is very slightly faster in the first set of pictures, and almost a frame faster in the second set of pictures. (2007 on the right)
1/4000s shutter speed
First way:
Second way:
The little white dot in the lower right of each picture is because the monitor was starting the refresh near the bottom of the screen before continuing from the top.
No, I don't have a CRT.
I've added some horizontal lines for easier reference. So, in this image, 3/10s of the current refresh was drawn.
I programmed it in Processing (processing.org)
I found a very poor quality CRT for my tests. It appears that the 2007WFP has no input lag.
The input lag is all a function of how fast the pixel response time is, not due to any pre-processing. I tried switching the ports each monitor used and it didn't make any difference
This software could also be used to test the time needed to switch between two colors. (almost 2 frames worth of time for white to black in these pictures)
How do you guys take such nice pictures with high shutter speed? I set up my old CRT by my monitor the other day to test out the input lag, but when I upped the shutter speed of my Olympus C-7070, both screens came out more or less black, impossible to see. Lowering the shutter speed makes the numbers of the stopwatch I was using blur together.
Also, stuff like this happened. I tried turning off the flash, only made things darker.
