In reference to this thread. I am looking to buy (might have to end up building) a rig for lab type purposes.
I plan on running Server 2008 with AD and Hyper-V
VM 1- Exchange
VM 2- Server 2008 IIS
VM 3- Sharepoint
VM 4- MS Search Server (I realize the resources required would allow this to be installed on one of the other VMs however for testing purposes this needs to be on its own server)
**VM 5 (if resources permit)- win 7 client
I am pretty sure any quad core CPU will do the trick, either Intel or AMD flavor. I am however asking which model would be the best bang for my buck. And a motherboard that will support this chip. From the motherboard I would like dual 10/100/1000 NICs and onboard videa and RAID. I am planning on getting 8gb RAM min, with the option to upgrade later.
So far I have only been specing out a system with desktop class CPUs. However is a server class chip my best bet? This will be running 24/7, so while power usage is not a primary concern, I do not want to go overboard with the power consumption. So which CPU and motherboard would you guys recommend while still keeping it somewhat budget friendly?
VM 1- Exchange
VM 3- Sharepoint
