New Intel 80gb G2R5... When (whether?) to flash?
DarkSideA8
Just got in my new drive. I'm planning to use it as the core of my new build, upgrading from XP Pro 32 to Win 7 Pro 64. It will be my OS & key app drive, while the new 1TB Caviar Black will be games/apps/storage.
Can I flash the SSD after the instal of Win 7 Pro 64, or do I need to plug it into this system before I begin the rebuild & flash it before I install the new OS?
BTW: having never flashed a drive before: do I need to download the update & burn it to a DVD to flash the SSD? (Link to instructions appreciated!)
TIA
Interesting to note that my Intel drive is "Made in China with partial foreign content"
While technically the new firmware is supposed to survive flashing with out corrupting your data, like that last firmware did. There's always some risk involved when flashing.
First of all, the last problems almost all occurred on drives with Win7 already installed, so why put yourself in that "higher risk" category of having Win7 already installed.
Second, why not minimize what you're risking by flashing it first.
If you flash after you've installed OS, you risk losing at least a few hours of install time, etc....
ex: Install OS, flash drive... something goes wrong & you need to reinstall OS, thats probably 2 hours of time.
SO the obvious logical choice is to flash the drive first.
P.S. I have a very similar set up. See sig. Though I already had a 640Gb black, so I got a second one so I'd have 1Tb+ of storage if I raid 0 them or leave them separate. Or I could Raid 1 them for data redundancy/ protection.
Flash took 2 , maybe 3 seconds. AHCI before, during, and after. Windows 7 HP 64bit was installed, no problems after the flash.
Oops - forgot about the AHCI issue! I'm fairly certain my current build doesn't have AHCI set up in the BIOS. Everything I've read says I want to be sure my SSD uses an AHCI BIOS.
So, does that fact change anything; i.e. do I need to wait until the new build to flash? (Will plugging in the new drive into a non AHCI system automatically set it up in IDE mode in a way that will prevent / make it difficult to change it to AHCI when I load up Win7?)
No, flashing in IDE or AHCI has nothing to do with actual use/operation of the firmware (even though Intel or others may recommend you flash in IDE mode).
You need to flash your drive to new firmware, install W7 and you games ON the SSD. It doesn't compare to the 1TB disk.
my tests here, and that 500GB Seagate is single platter, so you be the judge:
App. install times:
App. loading times:
Thanks. I was concerned that if I plugged in the SSD to my sys which is already set up in IDE it would make a later install of Win 7 in AHCI or RAID difficult.
So to recap:
1. Plug-n-play the SSD into any open SATA slot on my current sys;
2. Flash the drive;
3. Disassemble & reassemble, inserting ONLY the SSD (no HDDs at this point);
4. Enter the BIOS before beginning the OS install & set it to RAID FIRST;
5. Install the OS with only the SSD attached; and
6. then once the OS is functioning, plug-n-play the HDD & partition - right?
That's kind of a lot of work.
You want to plug your SSD in only first although I think it's not a big deal if your hard drives are plugged in also. Change to IDE if you want, although AHCI is supposed to work.
Flash the drive. Reboot and change to AHCI and install the OS with all the drives attached and you're done. Why would you mess with RAID if you only have 1 SSD?
I know hardly anything about the effects / benefits of IDE / AHCI / RAID - except what I've read here. Invisibill suggested that RAID incorporates AHCI & would probably be a better way of setting it up.
