Negative Decibel
- Dec 13, 2005
I've been reading all sorts of forums and articals... googling for hours and days.
I have found a few articals where people have submerged thier radiator in a bucket of water, usually with ice in it in order do get some extreme overclocking...
The problem with this is, the water is so cold that you would eventually get condensation on the waterblock, etc. (not very practical for everyday use)...
ok.... this is where I start to get wierd...
Now, the whole idea behind water cooling is that water conducts heat better than air, right?
Well, intead of having a large radiator with a few noisy fans on it... Why couldn't I place my radiator in a small tank of water at room temp (that would fit in the upper portion of a fulltower case) in order to cool the radiator off???? no more fans.
As owner of several aquariums, (with fish in them even), I know that evaporation would be a problem, and I want the tank in a matter that any evaporation will go straight out of the tank and not back into the case... This leaves me with sortof a piano hinge contraption for the top panel of the case.
I allready have purchased a very tall, fulltower case, and about to start cutting it up. I just wanted some final input from all of you guys.
Have I gone mad? Is this idea even concieveable?
I just want to do something that hasn't done before... usually there is a reason it hasn't been done; it wont work. This just sounded like a good idea to me
