New i7 Build Review
cramb0
I've been looking at these forums, several others and some reviews for about 3 weeks and have come up with an i7 build that I'd like to run by yall. Here are the answers to the sticky questions followed by my build.
Gaming mostly.​
$1500-$2000 with tax and shipping included​
3) Where do you live?
Texas​
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
This is a complete new build. I have an old P4 setup from about 4 years ago that just isn't cutting it anymore.​
I will be reusing one of the optical drives from my old computer.​
6) Will you be overclocking?
Yes. I would like to overclock to at or around 4GHz.​
7) What size monitor do you have or plan to have?
I have a 19" Dell and plan to buy a 24" BenQ (see link below).​
On or before January 15th.​
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
None really. I may Crossfire one of these days, but I doubt it.​
My Build
COOLER MASTER HAF 932 RC-932-KKN1-GP Black Steel ATX Full Tower Computer Case - Retail $159.99
Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM $69.99
SAPPHIRE 100251SR Radeon HD 4870 X2 2GB 512-bit (256-bit x 2) GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail $449.99
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail $124.99
ASUS P6T Deluxe LGA 1366 Intel X58 ATX Intel Motherboard - Retail $299.99
COOLER MASTER V8 RR-UV8-XBU1-GP 120mm Rifle CPU Cooler - Retail $69.99
Intel Core i7 920/OCZ Gold 6GB (3 x 2GB) DDR3 1600 Combo $459.98
Newegg Total (shipping included): $1,676.70
Monitor
BenQ G2400WD ~$355
Grand total: ~$2,031.70
As you can see, I am slightly above my budget, but that is fine. I'm really wanting to build something that will last me another 4 years with minor upgrades done during that time.
Any suggestions/questions/advice/comments are welcomed and encouraged. :) Thanks in advance!
Edit: I already have a copy of 64 bit Vista so I don't need to purchase an OS.
yea mate, looks like a really nice build. i dont really like the case to be honest, i am biased towards lian li's. but they would put you further over your intended budget.
Yeah, to be honest, I'm not real wild about the case either. My previous case is a Lian Li, and I love it. I chose this case for functionality more than aesthetics.
1. Hunt for live cashback deals. Newegg is 2.75% Therefore that would be about $50 cashback.
2. The PCP&C 750 is a bit cheaper and has equivalent specs. Save about $50
3. If you really just plan on running single drive, you do not need a full tower case IMO. A mid tower would probably be a bit better. Save about $50
So for doing those three things with ZERO change to machines ability, you save about $150. Take the money and put it in a savings account.
Thanks for the advice. My main concern with mid tower cases was knowing if the heatsink was going to fit in the case. I knew that it would fit in the HAF which is part of why I went with it. I really need to do a little more research on cases.
How you going to install this with out a DVD drive?
Why can't he use the optical drive? :p But if you were looking for a way to install it without one, you could do it via the network, if you set one up.
Ah missed that one. I read it was a complete build so I was thinking he was going to need one. Oh well moving on
Just curious, but what made you choose the V8 over the TRUE120.1366?
300 is steep for the case and power supply. If you can I would look at some mid sized cases for around 80 bucks and get 600 watt power supply for about 90-100 more. That will save you 100 bucks.
While the ASUS motherboard is good if you do not need the features and are willing to go down to 3 Dimms there is a cheaper GIGABYTE board out there for around 220.
I can not post anything since I am at work, but to be frank I am sure you could cut 300 off the cost of that computer.
Most people I know that would spend $2k on a system don't bother trying to save $300. I spec'd a system for a buddy of mine, and he said, "what else can I buy to reach my budget?"... lol. So... we got him a $350 case. haha!
Money would be better spent getting a one bay NAS with a hard drive for a constant back up solution if you are looking to blow 300 dollars.
Honestly, I don't remember. I have done a lot of research the past few weeks and feel like I have a touch information overload. Anyway, I think it had something to do with they performed about the same and were about the same price except you would have to buy a retention bracket separately for the 1366. It looks like that isn't such a pain now, (Link) but I can't get that from newegg and would like to get as many things from there as possible. More or less, I saw the performance as a wash and would just go with the "easier" choice.
Edit: Newegg just sold out of the V8s until 1/27 so I may end up going with the TRUE 120.1366 anyway. Just more for me to think about. ;)
I don't care about cost that much, but saving money is always good. I've been building computers for about 10 years and have always used ASUS boards. I have always had good luck with them so they are a brand I trust. However, I am open to specific suggestions. I will research more options in the meantime.
Edit: I also went with the 750 watt power supply because I used a PSU calculator on some other thread, (sorry I can't find the link right now) but it said that I needed slightly less than 600W. So I decided on the 750 for a little headroom.
I may actually go with the ASUS P6T. It looks to be about the same as the deluxe version except it has 2 fewer SATA ports (6), 2 fewer USB ports (6), and a single onboard NIC as opposed to dual.
Of course there are different onboard audio and network chipsets and RAID controllers, but I don't really care about that either. I probably won't ever do RAID in this setup.
