Hi All
I am looking to build a new hypervisor host for my job/career/training/lab. I am in an IT role that involves moving between dozens of clients and keeping up with all the new technologies is a must!
Currently I run the following setup with Hyper-V 2012 R2 (Core):
Mobo: Supermicro X10SL7-F
CPU: Intel Xeon E3-1230 V3 Haswell
RAM: 4 x 8GB DDR3 ECC 1600 (32GB in total)
Case: Fractal Design Mini
PSU: Seasonic 550W
Drives: 2 x 128GB Samsung Pro 840
1 x 256GB Samsung Pro 830
1 x 512GB Samsung Pro 850
Fans: 5 BeQuiet fans (120/140mm) for cooling
IcyDock 5.25" bay to house the 4 SSD drives
HDD: Western Digital 4TB Red
This build has been fantastic for HyperV and ESXi but unfortunately I am limited by the 32GB of RAM. I currently run 10 VMs but am unable to start/create anymore VMs. I run (but am not limited to): Exchange, SQL, Citrix, Remote Desktop Services, Veeam, Active Directory, IIS, etc. I need to run at least another 10 VMs (Lync, System Center, PRTG, vCenter etc).
I have been thinking about the following build:
Mobo: Supermicro X10SRA-F
CPU: Intel Xeon E5-2630 V3 Processor Haswell
RAM: 4 x 32GB DDR4 (128GB in total)
Case: Fractal Design Define XL R2 Black Pearl
I was going to reuse the PSU and the SSD/HDD drives I have BUT the questions I have are:
1)I currently use no RAID and considering how much I rely on this build I would like to have some protection against hard drive failures on the SSDs (all my VMs are on SSD storage and the SATA drive is used for backups only). So what sort of RAID setup should I use for VMs? RAID 1? 10? 5? I don't mind buying more drives
2) I'm keen on using the new PCI Express SSD drives for some VM storage as they are wicked fast. Can one use multiple PCIe SSD drives in a RAID setup? I won't be booting off them and will only be storing VMs on them. Could I use 4 in a RAID 5? I want the system to be snappy/fast to use as I test so much software for my job that I can't afford to sit around waiting hours for something to happen! Should I consider the Intel 750? Samsung 950 PCIe? I'm a bit out of touch with storage.
3) I do have an IBM MegaRAID card which I know works with ESXi (I can't remember the exact model as I type this but it has 512MB cache onboard
Ideally this new setup should work with HyperV and ESXi. My main concern is the storage system. I want the IOPS to be good and want to be able to upgrade the machine as time goes by. I can still add more RAM to this motherboard!
Look forward to repsonses. If I have lefy anything important out then let me know!
PSU: Seasonic 550W
