New Home Server Advice
gtg738w
Hey guys, I’m looking for some advice for setting up a server to use for storage and backup at home. Additionally, I’d like to run Apache to have a light web server as well. The goal is to have a system to support two MacBook Pros and a Mac mini. Data is mostly photos, music and documents so I’m currently targeting in the ~1.5TB available range.
The first question is selecting a reasonable backup strategy. Since this is a home application, I’m not too concerned with uptime, I just need the data to be safe. One option would be to have one disk for primary storage, a second for backups in the same machine, and a third disk to swap out with the backup so one copy could be stored in a safe place. An alternative I’ve heard of is a mirror with two disks and then swapping one of those periodically for a backup but this sounds potentially dangerous trying to rebuild an array on a regular basis. Has anybody tried either of these methods? I’m leaning towards a FreeBSD zfs system so the redundancy of the mirror would be nice for self healing.
The second question is for hardware. Right now, I have an AMD 3200+ machine that is not being used for anything. The problem is, it has an Asus KV8 SE Deluxe that doesn’t support hot swapping of SATA drives. Can anybody recommend a SATA card (PCI) that would add this and work well with FreeBSD? My other choice is to upgrade to a “modern” system. I saw the FreeBSD handbook recommends better than a 486 and 24MB of RAM. I’m guessing zfs and a few other options would be much happier with more than that though. Any advice for a minimum configuration that could be expected to perform reasonably well and last for about ~4-5 yrs?
Thanks for your help, I’ve seen an impressive amount of experience in this forum and I’d appreciate any advice or comments you care to pass along.
Use a USB drive for a backup. Or even a USB SATA drive dock.
You can hot swap those.
