formula409
- Apr 7, 2005
Looks like the top grid of 5 heatpipes need more spacing apart so heat can be spread across the fins more evenly
It is different. This is based off that cooler but this one is different the the Si-120. For one, the fins will be an alloy that sheds heat faster. The pipes internals will have a different formula and chemical then used in the Si=120.
Tests would be made on the 2000 series. Possible 2219. 2000 series will not anodize right, so it would be bare as a final product. I cannot tell you what will be in the pipes.....if I did, I would have to Frag you.
The sharp edges on the fins look dangerous for installation.
BTW, how do you install it onto the mobo with the cylinders on the base?
It will be a contract. Designs will change as prototypes are made. I would consider sending out prototypes for people to beat on. Clips will be for AM2, 775, 1207(F), and 775. The renderings on this site are of one design. Get input and such on looks and what others would think would work better. prototypes can be made of a few designs. I will post one called the Six Shooter.
Make the pipes alternate direction, some coming from the front and some from the back. As heat travels down the pipes it sheds into the fins, having them all on one side would be uneven heat transfer.
It's harder to mount that though... Too much stuff in the way, unfortunately. Most boards have ONE side without a NB HSF, caps or other invading bodies, to mount a HSF like this.
