Lisa Gerrard
- Aug 18, 2013
Hi, first I bought 2 Seagate ST3000DM001 and now 8 Seagate ST4000DM000, to replace old 2TB HDD in my tower; I did initialized (GPT), partitioned (just one partition) and tested (2 passes with badblocks) them with gparted and everyone seemed ok, I use w7 ultimate 32bit, no raid
In just 2 weeks I got these problems (never happened in last 5 years):
1) When I started to transfer some files to one new ST4000DM000 (maybe a pure coincidence) I got a problem and the partition of one ST3000DM001 get corrupted losing lot of data. I wiped it and rebuilt the partition
2) While coping a big folder (about 1TB) system crashed and get a bsod (maybe problem was a windows update just done), now I use teracopy and copy is not more an issue
3) After I find out that hd tune was showing problems for one ST4000DM000 (End To End Error Detection 88 88 99 12 failed, Interface CRC Error Count 200 200 0 25 attention : do you suggest me to rma it or wipe it and rebuild the partition? it works good, but its still under warranty)
4) Gparted showed these warnings for at last 2 ST4000DM000 The backup GPT table is corrupt but the primary appears OK and "The backup GPT table is not at the end of the disk, as it should be. This might mean that another operating system believes the disk is smaller"
5) Now file system of another ST4000DM000 get damaged and lose data after chkdsk (it works good and smart info are ok)
Could be just bad luck? Maybe I did some mistakes with gparted? Could be an hardware related problem? Please, do you suggest me to keep to use everything in this way or try to change something?
Thank you and best regards
