New gaming build (first timer, advice needed).
Karamazov
Hey everybody! I hope this isn't rude to be asking for build advice in a first post, but I'm building my first computer and would like to have some input on the parts i've picked out, and some general advice on my build.
Below are the initial parts i've picked out, i'm building this with a $2,500 budget in mind, and won't be needing a keyboard, mouse, or monitor.
Case:LIAN LI PC-65B Black Aluminum ATX Mid Tower Computer Case
Motherboard: ASUS P5K DELUXE/WIFI-AP LGA 775 Intel P35 ATX Intel Motherboard
Graphics Card: BFG Tech BFGR88768GTXOCE GeForce 8800GTX 768MB GDDR3 PCI Express x16 OC HDCP Video Card
PSU: SeaSonic M12 SS-700HM ATX12V/EPS12V, 80Plus, Active PFC, RoHS, Dual-Fan, 700W Power Supply
Processor:Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Processor Model BX80562Q6600
RAM: CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
HDD: 2X
Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive
DVD/CD Drive:LITE-ON Black 16X DVD-ROM 52X CD-R 32X CD-RW 52X CD-ROM 1.5MB Cache SATA Combo Drive
CPU Fan:Tuniq Tower 120 P4 & K8 CPU Cooler
Total, without OS: $1,880.90
While this is will be the first computer I'll be building I'm not completely inexperienced with this sort of thing. I've formatted my current computer, installed new ram, and put in a new video card. But beyond that this will all be new to me. I don't think I'll want to upgrade to Vista (right now at least) but I don't know whether to get 64 bit XP or stick with 32 bit. I'd like to try overclocking (or should I just leave it alone?). Also, should I get DDR3, or stick with DDR2?
Thanks.
That RAM you have chosen seems to be a bit overpriced unless I'm blatantly missing something. I'd recommend this instead. The Abit IP35 Pro seems to be a pretty popular motherboard at the moment, you might want to take a look at it (pretty thorough review here). If you're going to buy an OS, I'd recommend getting Vista x64. You'll most likely be moving over to it in the near future anyways (especially as a gamer), so might as well not spend any extra money on XP if you don't already have a retail box lying around. I wouldn't worry about DDR3 at all for now, it seems to be quite a way off from mainstream.
OCing these days is pretty simple and much more foolproof than in the past. There are plenty of guides around to get you started and if you run into any trouble the OC section on this forum is great. As long as you approach with caution its very unlikely that you will damage anything.
And one more thing that's very important... if you're getting this for all of the games coming out later this year, I recommend that you wait until those games are actually out, or close. With X38, Penryn, and 9800s looming on the horizon it'd be a shame to jump the gun. If you're buying it for something that's out right now, more power to you, because there will always be something bigger and better around the corner. But if you don't need it til November, wait til November.
I read an article (I think it may have been this site?) that said performance in Supreme Commander (a HUGE reason i've decided to upgrade) was worse under Vista than XP. I figured I could stick with XP for now and then get Vista when a "must have" DX10 game is released.
Ah, thank you. Thats good to hear.
Well, I thought about this, but since things seem to be pretty cheap right now, I decided to go ahead and build one instead of waiting a couple months and paying out the ass for just released products (or am I completely wrong in thinking this?).
Its true, as it is right now, games generally perform a bit better in XP than Vista. With my machine I've been able to run Supreme Commander at 1600x1200 4x AA 16x AF without a hitch in Vista in the few times I've played it since building, and with a quad and GTX you can do even better. If you're referring to the DX9 vs DX10 performance, then yes, many of the DX10 patches have led to pretty serious performance issues for very minor increases in eye candy, but this seems to be much less of an issue in the newer games being released under DX10 such as World in Conflict. If you already have XP available to install you'd be fine to stick with it (and I probably would if that's the case), I was just advising against spending any extra money since you'll probably want to move to Vista in the coming months anyways.
As for the idea of waiting; yes, the new products will likely be quite expensive. However, with these products released, it will also be very likely that the older models (p35, 65nm quads, 8800s) will go down in price. And the performance of these new products might be worth the premium you'll pay, but all we can do is speculate until they're actually out. Its really up to you, but buying ahead of time tends to leave people kicking themselves over whatever new great product is out by the time they do need it. But since you said Supreme Commander is one of the big reasons you want this build, going with it now and getting these months to enjoy your games isn't a bad thing either, its really up to you.
$178 with no rebate gets you the SilverStone Decathlon 750watt single 12v rail modular PSU. Better deal, I'd say. Also, you aren't going to need anything more than the Corsair 620HX for a Quad and a single GTX, and that would save you $40+ even over the SilverStone. 650+ is only necessary for SLI setups, and the P35 boards do not support SLI.
Find the cheapest DDR2-800 at 4-4-4-12 you can, should be around $90 and is probably G.Skill. It will serve you well. (You aren't likely to get to DDR2-800 speeds with a Quad on air cooling, much less surpass them, so DDR2-1066 and higher really isn't necessary.)
That particular Lian Li has 4 80mm fans... which means it will be loud. Very loud. I'd strongly suggest something with 2 or more 120mm fans instead. Maybe this PC-7B Plus II instead?
Jeez, everything I wanted to say has been covered. I agree with whats already been stated. :D
also look for any deals on HD's, but overall the setup looks good.
I'll do you one better - try a Thermaltake Toughpower 750W for $125. Great reviews for this thing.
Ha, I already bought the corsair, but I might stop by Fry's and pick up that one!
EDIT: whoops I thought this was another thread... but still I might just go buy that one.
I looked around on newegg and found this for $80 after a mail in rebate. Since it's much cheaper than my other ram I was thinking of going for 4 gigs instead of two. (is Crucial a good brand? that review about it causing blue screens makes me nervous)
Noise wasn't really a concern of mine when I picked that case. I wanted something simple, and functional with a side window (about the only decoration I want).
Crucial is the best for DDR2. The fact is, no brand of RAM is perfect... there will always be some unlucky people who get bad sticks, which will cause blue screens. The good thing is, they have lifetime warranty, so they're easily replaceable.
Crucial is a division of Micron, the maker of the famous D9GMH memory chips. If you order some decent (not the cheapest) crucial ram, you will likely get D9GMH chips.
They also have a lifetime warranty and I've used them many times.
I'd still rather go with a single 12v rail PSU and a non Themaltake, though if that's one of the CWT's (I know the 850 and up Toughpowers are, but I don't think the 750s are) it would be worth getting, potentially.
Just FYI, it is made by CWT. Also, the 140mm fan is a Yate Loon D14SM-12.
JonnyGuru Review
Score: 9/10
"In the past, Thermaltake has gotten a lot of grief. They had been known to sell power supplies that were "behind the times" in terms of the ATX standards, but dressed up in a lot of glorious bling giving the power supplies an appeal to the naive. Certainly the best way to shake that old stigma is to release a product that is a no holds barred kick butt power supply. The Toughpower 750W fits that bill with plenty of power, good efficiency, active power factor correction, and solid construction. This PSU gets a well-deserved "jonnyGURU Recommended."
