or an 80 to 92mm fan adapter would work. If you want to keep with the current size, do a push/pull configuration with a pair of SilenX 80mm fans, or, use a Panasonic Panaflo 80mm. What are your system specs for the Shuttle? CPU/Video/Current Temps/etc..
I too am running a 2500+ in mine. I stuck a 2 wire panaflow in place of the stocker, and she's very quiet and i run stable at 2.2 ghz, with no heat woes.
What kind of memory do you have to get it to 2.2? So you're saying that your fan upgrade alone, allows you to run the machine faster?
Is the 2 wire panaflo quieter than the stock fan? I believe I changed my stock fan, but can't remember with what, it has been 16 months since I got my SN41G2.
No, I'm not saying that the fan alone let me run faster. I'm saying that the $4 80mm panaflo I bought is sufficient to let me overclock my cpu. My memory is pc2100 from crucial. I can't quite run it at the 200 mhz I run the processor at, but I can run it at about the 83% mark (since we have no voltage mod. in the bios). So, I run staggered. Would I get better performance with better memory? Sure. Do I have the money for it right now? No.
And the two wire/three wire thing. I messed up when I ordered. I didn't even bother to think that the fan in the case had 3 wires. I just stick the 2 wires on 2 of the 3 pins and she runs full speed (instead of that stupid varied fan rate) but yet its quite a bit quieter than the old fan was. If I had it to do over again, I certainly would have gotten the 3 wire fan...but oh well..doesn't matter.
I don't know...probably another panaflo. I'm pretty impressed with the little guy, and it was under $5 shipped...although i don't remember where I got it. I've never bought a 'quality' fan before, so i don't know too much about them.
