New Fan Controller
So this is a 5-OFF-12 switch, not like a rheostat... but you're right it does look pretty good, as long as those switches aren't more than ~1" long. If it could be kept rather low profile that'd be saweet. Go for it.
your right, that is an issue for me as my Panaflos will not always start at 5V...I prefer to run them at just over 7V
damn...
after all these years no1 makes a decent and affordable fan controller?
back to looking at the Zalman, but it is going to be maxed out with 3 of these on one channel
http://www.svc.com/fba12g12l1bx.html
I prefer to controll all 3 fans on my radiator at once rather than run them seperately which would be dumb....I only really need 4 ports too no 6...
Heck I don't think this will controll my Case lighting because it may pull more than 7 watts at most:(
That leaves only the new sunbeam, but its hidious....
It's almost impossible to sink 60w on a varistor... Your best bet would be to use a 7v regulator that can handle up to 2A, and keep it at 7v constantly.
well I dont need 60 watts :p I jsut wanted something that I can hook 3 Panaplo L1A's on one knob to and not have it 1) burn out or 2) look like crap or 3) have really bright annoyig LED's that keep me awake at night like my 4 channel sunbeam
You may want to reconsider this controller then as you stated you didnt want
The product description specifies..."the switches use colored LEDs to show what state they are in! Blue indicates 5V, Red indicates 12V and neither LED is lit when the switch is off."
Video of how bright they are is found here.
This one has 18W/1.5A capacity per channel so it would take three of those fans easily.
http://www.aerocool.us/peripheral/fp-01/fp-01.htm
Unlike most such non rheostat controllers it seems to have actual output filtering making it behave similar to rheostat with all fans I've tested.
(no buzzing noises from some fans or fan refusing to lower RPM)
Resolder to 7V instead?
You shouldn't connect anything between two voltage:
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story3&reid=120
my last Aero Cool sucked so thats out.
Is my only real option to buy the same one and change out the LED's or remove them?
Anyone know if this one looks better/worse than the older sunbeam..
http://www.svc.com/rhk-ex-bk.html
better than
http://www.svc.com/bus-54-bk-24.html
If so are the knobs on the new model removable (I want to paint the front panel completely black)
This one looks good mut my LED setup may draw up to around 12W, although it needs less to run I'm not sure how my current limiting circuit would draw from teh Fan Controller. It's just a simple LM317T in current regulation mode, which drops all eccess power as heat, but I don't know what kinda load it would actualy put in the fan controller.
