Matthyahuw
- Nov 13, 2007
Okay, I'm sure I've covered all my bases on this.
I have bought an ACTIVE DP-to-DVI adapter that's even AMD-certified
http://www.newegg.com/Product/Product.aspx?Item=N82E16814999032
I have a Sapphire 5670 that supports Eyefinity
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102870
I have 2 ASUS VE248Hs (the new LED-backlit ones) which are 16:9 @ 1920x1080
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236102
and 1 Samsung 24" 16:10 @ 1920x1200
setup is like this:
----ASUS VE248H--------------------------ASUS VE248H-------------------------Samsung
DVI on the DP adapter--------------------------HDMI----------------------------------Native DVI
I can't enable all three monitors at the same time.
I can only choose 2 of the 3.
I have googled this & it says it is because you don't have an active adapter, yet I do & it is even certified.
Am I missing something???
Thanks
setup is like this:
Thanks
