I decided several weeks ago to create a VMware ESXi 4.1 host server to virtualize several machines that I usually leave running 24/7, and to enable me to play around with Server 2008, etc.
Ultimately, this is what I want to achieve:
-Windows Home Server, running with RAW access to either my SATA drives directly or a Dell Perc 5/i card running them in RAID 5
-Ubuntu 10.1 Counter-strike: Source dedicated server
-OpenVPN Server
-Server 2008 R2 machine as my domain controller/WDS imaging box
Without thinking, I purchased a hex-core 1055T for use in my current AMD AM2/AM3 motherboard. It turns out, most, if not all (including mine) AM3 boards do not support the AMD equivalent of VT-d for direct hardware access in VMware. As such, I have chosen to make my Core i7 rig become my ESXi machine.
Specs:
Intel Core i7 920
ASUS P6T-SE (confirmed VT-d support)
6 GB DDR3-1333
640GB WD Black drive for ESXi and datastores
3x2 TB Samsung F3 drives for WHS storage
5x1 TB 1TB drives in RAID 5 for additional storage.
Dell Perc 5/i RAID card
Intel PCI-express 4x Dual 10/100/1000 nic (http://www.newegg.com/Product/Product.aspx?Item=N82E16833106015)
Questions:
Will this amount of RAM and CPU be adequate for my current needs?
Is dedicating one NIC to WHS a good idea, or would I be better served by selling it so I can buy that Perc 5/i card? (I have a single gigabit intel nic I can use)
Will I have too much I/0 for that RAID 5 array? If so, I can get a 2.5" to 3.5" hard drive enclosure and run four 2.5" disks in Raid 1 + 0.
Thanks!
Any other suggestions are welcome!
-OpenVPN Server
Specs:
Intel Core i7 920
6 GB DDR3-1333
Questions:
Thanks!
