Wheresatom
- Mar 20, 2007
This is a bit new to me. I am not used to having EUE errors. I came home today and this is what my log said:
Is this an error based on my overclock (which I backed off a little, immediately after seeing this) or does this have to do with high temperatures or both? Or, is this a completely unrelated problem? Thanks all.
Code:
[13:44:05] Completed 247500 out of 250000 steps (99 percent)
[14:00:51] Writing local files
[14:00:52] Completed 250000 out of 250000 steps (100 percent)
[14:00:52] Writing final coordinates.
[14:00:53] Past main M.D. loop
[14:00:53] Will end MPI now
[14:01:53]
[14:01:53] Finished Work Unit:
[14:01:53] - Reading up to 21421872 from "work/wudata_02.arc": Read 21421872
[14:01:53] - Reading up to 596232 from "work/wudata_02.xtc": Read 596232
[14:01:53] goefile size: 0
[14:01:53] logfile size: 203301
[14:01:53] Leaving Run
[14:01:55] - Writing 22227777 bytes of core data to disk...
[14:01:55] ... Done.
[14:01:55] - Failed to delete work/wudata_02.sas
[14:01:55] - Failed to delete work/wudata_02.goe
[14:01:55] Warning: check for stray files
[14:01:55] - Shutting down core
[14:03:55]
[14:03:55] Folding@home Core Shutdown: FINISHED_UNIT
[14:03:55]
[14:03:58] CoreStatus = 64 (100)
[14:03:58] Sending work to server
[14:03:58] + Attempting to send results
[14:08:02] + Results successfully sent
[14:08:02] Thank you for your contribution to Folding@Home.
[14:08:02] + Number of Units Completed: 11
[14:10:23] - Preparing to get new work unit...
[14:10:23] + Attempting to get work packet
[14:10:23] - Connecting to assignment server
[14:10:24] - Successful: assigned to (171.64.65.64).
[14:10:24] + News From Folding@Home: Welcome to Folding@Home
[14:10:24] Loaded queue successfully.
[14:10:41] + Closed connections
[14:10:41]
[14:10:41] + Processing work unit
[14:10:41] Core required: FahCore_a1.exe
[14:10:41] Core found.
[14:10:41] Working on Unit 03 [June 6 14:10:41]
[14:10:41] + Working ...
[14:10:41]
[14:10:41] *------------------------------*
[14:10:41] Folding@Home Gromacs SMP Core
[14:10:41] Version 1.74 (March 10, 2007)
[14:10:41]
[14:10:41] Preparing to commence simulation
[14:10:41] - Ensuring status. Please wait.
[14:10:58] - Assembly optimizations manually forced on.
[14:10:58] - Not checking prior termination.
[14:11:03] - Expanded 2412466 -> 12890749 (decompressed 534.3 percent)
[14:11:03] - Starting from initial work packet
[14:11:03]
[14:11:03] Project: 2653 (Run 3, Clone 34, Gen 70)
[14:11:03]
[14:11:04] Assembly optimizations on if available.
[14:11:04] Entering M.D.
[14:11:10] Rejecting checkpoint
[14:11:11] Protein: Protein in POPCExtra SSE boost OK.
[14:11:11]
[14:11:12] Extra SSE boost OK.
[14:11:12] Writing local files
[14:11:13] Completed 0 out of 500000 steps (0 percent)
[14:23:25] Writing local files
[14:23:26] Completed 5000 out of 500000 steps (1 percent)
[14:35:35] Writing local files
[14:35:35] Completed 10000 out of 500000 steps (2 percent)
[14:47:46] Writing local files
[14:47:46] Completed 15000 out of 500000 steps (3 percent)
[14:59:57] Writing local files
[14:59:57] Completed 20000 out of 500000 steps (4 percent)
[15:12:07] Writing local files
[15:12:07] Completed 25000 out of 500000 steps (5 percent)
[15:24:17] Writing local files
[15:24:17] Completed 30000 out of 500000 steps (6 percent)
[15:26:24] .. Done.
[15:26:24] - Failed to delete work/wudata_03.arc
[15:26:24] - Failed to delete work/wudata_03.xtc
[15:26:24] - Failed to delete work/wudata_03.bed
[15:26:24] - Failed to delete work/wudata_03.sas
[15:26:24] - Failed to delete work/wudata_03.goe
[15:26:24] Warning: check for stray files
[15:26:24] e
[15:26:24]
[15:26:24] Folding@home Core Shutdown: EARLY_UNIT_END
[15:26:24] Finalizing output
[15:26:24] our computer (issues
[15:26:24] such as high temperature, overclocking, etc.).
[15:26:24] Going to send back what have done.
[15:26:24] logfile size: 8784
[15:26:24] - Writing 9333 bytes of core data to disk...
[15:26:24] ... Done.
[15:28:24]
[15:28:24] Folding@home Core Shutdown: EARLY_UNIT_END
[15:28:24]
[15:28:28] CoreStatus = 7B (123)
[15:28:28] Client-core communications error: ERROR 0x7b
[15:28:28] Deleting current work unit & continuing...
[15:30:48] - Preparing to get new work unit...
[15:30:48] + Attempting to get work packet
[15:30:48] - Connecting to assignment server
[15:30:52] - Successful: assigned to (171.64.65.64).
[15:30:52] + News From Folding@Home: Welcome to Folding@Home
[15:30:52] Loaded queue successfully.
[15:31:06] + Closed connections
[15:31:11]
[15:31:11] + Processing work unit
[15:31:11] Core required: FahCore_a1.exe
[15:31:11] Core found.
[15:31:11] Working on Unit 04 [June 6 15:31:11]
[15:31:11] + Working ...
[15:31:11]
[15:31:11] *------------------------------*
[15:31:11] Folding@Home Gromacs SMP Core
[15:31:11] Version 1.74 (March 10, 2007)
[15:31:11]
[15:31:11] Preparing to commence simulation
[15:31:11] - Ensuring status. Please wait.
[15:31:28] - Assembly optimizations manually forced on.
[15:31:28] - Not checking prior termination.
[15:31:33] - Expanded 2412466 -> 12890749 (decompressed 534.3 percent)
[15:31:33] - Starting from initial work packet
[15:31:33]
[15:31:33] Project: 2653 (Run 3, Clone 34, Gen 70)
[15:31:33]
[15:31:35] Assembly optimizations on if available.
[15:31:35] Entering M.D.
[15:31:41] Rejecting checkpoint
[15:31:42] Protein: Protein in POPC
[15:31:42] Writing local files
[15:31:43] Extra SSE boost OK.
[15:31:43] Writing local files
[15:31:43] Completed 0 out of 500000 steps (0 percent)
[15:33:49] Gromacs cannot continue further.
[15:33:49] Going to send back what have done.
[15:33:49] logfile size: 0
[15:33:49] Warning: Core could not open logfile.
[15:33:49] - Writing 536 bytes of core data to disk...
[15:33:49] ... Done.
[15:33:49] - Failed to delete work/wudata_04.sas
[15:33:49] - Failed to delete work/wudata_04.goe
[15:33:49] Warning: check for stray files
[15:33:49]
[15:33:49] Folding@home Core Shutdown: EARLY_UNIT_END
[15:33:49]
[15:33:53] CoreStatus = 7B (123)
[15:33:53] Client-core communications error: ERROR 0x7b
[15:33:53] Deleting current work unit & continuing...
[15:36:13] - Preparing to get new work unit...
[15:36:13] + Attempting to get work packet
[15:36:13] - Connecting to assignment server
[15:36:14] - Successful: assigned to (171.64.65.64).
[15:36:14] + News From Folding@Home: Welcome to Folding@Home
[15:36:14] Loaded queue successfully.
[15:36:28] + Closed connections
[15:36:33]
[15:36:33] + Processing work unit
[15:36:33] Core required: FahCore_a1.exe
[15:36:33] Core found.
[15:36:33] Working on Unit 05 [June 6 15:36:33]
[15:36:33] + Working ...
[15:36:33]
[15:36:33] *------------------------------*
[15:36:33] Folding@Home Gromacs SMP Core
[15:36:33] Version 1.74 (March 10, 2007)
[15:36:33]
[15:36:33] Preparing to commence simulation
[15:36:33] - Ensuring status. Please wait.
[15:36:50] - Assembly optimizations manually forced on.
[15:36:50] - Not checking prior termination.
[15:36:55] - Expanded 2412466 -> 12890749 (decompressed 534.3 percent)
[15:36:56] - Starting from initial work packet
[15:36:56]
[15:36:56] Project: 2653 (Run 3, Clone 34, Gen 70)
[15:36:56]
[15:36:57] Assembly optimizations on if available.
[15:36:57] Entering M.D.
[15:37:02] Rejecting checkpoint
[15:37:03] Protein: Protein in POPCExtra SSE boost OK.
[15:37:03]
[15:37:04] Extra SSE boost OK.
[15:37:04] Writing local files
[15:37:05] Completed 0 out of 500000 steps (0 percent)
[15:49:35] Writing local files
[15:49:36] Completed 5000 out of 500000 steps (1 percent)
[16:02:06] Writing local files
[16:02:06] Completed 10000 out of 500000 steps (2 percent)
[16:05:00] often see other project units terminating early like this
[16:05:00] too, you may wish to check the stability of your computer (issues
[16:05:00] such as high temperature, overclocking, etc.).
[16:05:00] Going to send back what have done.
[16:05:00] logfile size: 8812
[16:05:00] - Writing 9362 bytes of core data to disk...
[16:05:00] ... Done.
[16:05:00] - Failed to delete work/wudata_05.sas
[16:05:00] - Failed to delete work/wudata_05.goe
[16:05:00] Warning: check for stray files
[16:05:00]
[16:05:00] Folding@home Core Shutdown: EARLY_UNIT_END
[16:05:00] Finalizing output
[16:05:00] : Core could not open logfile.
[16:05:00] - Writing 550 bytes of core data to disk...
[16:05:00]
[16:05:00]
[16:05:04] CoreStatus = 7B (123)
[16:05:04] Client-core communications error: ERROR 0x7b
[16:05:04] - Attempting to download new core...
[16:05:04] + Downloading new core: FahCore_a1.exe
[16:05:05] + 10240 bytes downloaded
[16:05:05] + 20480 bytes downloaded
[16:05:05] + 30720 bytes downloaded
[16:05:05] + 40960 bytes downloaded
[16:05:05] + 51200 bytes downloaded
[16:05:05] + 61440 bytes downloaded
[16:05:05] + 71680 bytes downloaded
[16:05:06] + 81920 bytes downloaded
[16:05:06] + 92160 bytes downloaded
[16:05:06] + 102400 bytes downloaded
[16:05:06] + 112640 bytes downloaded
[16:05:06] + 122880 bytes downloaded
[16:05:06] + 133120 bytes downloaded
[16:05:06] + 143360 bytes downloaded
[16:05:06] + 153600 bytes downloaded
[16:05:06] + 163840 bytes downloaded
[16:05:06] + 174080 bytes downloaded
[16:05:06] + 184320 bytes downloaded
[16:05:06] + 194560 bytes downloaded
[16:05:06] + 204800 bytes downloaded
[16:05:06] + 215040 bytes downloaded
[16:05:06] + 225280 bytes downloaded
[16:05:06] + 235520 bytes downloaded
[16:05:06] + 245760 bytes downloaded
[16:05:06] + 256000 bytes downloaded
[16:05:06] + 266240 bytes downloaded
[16:05:06] + 276480 bytes downloaded
[16:05:06] + 286720 bytes downloaded
[16:05:06] + 296960 bytes downloaded
[16:05:06] + 307200 bytes downloaded
[16:05:06] + 317440 bytes downloaded
[16:05:06] + 327680 bytes downloaded
[16:05:06] + 337920 bytes downloaded
[16:05:06] + 348160 bytes downloaded
[16:05:06] + 358400 bytes downloaded
[16:05:06] + 368640 bytes downloaded
[16:05:06] + 378880 bytes downloaded
[16:05:07] + 389120 bytes downloaded
[16:05:07] + 399360 bytes downloaded
[16:05:07] + 409600 bytes downloaded
[16:05:07] + 419840 bytes downloaded
[16:05:07] + 430080 bytes downloaded
[16:05:07] + 440320 bytes downloaded
[16:05:07] + 450560 bytes downloaded
[16:05:07] + 460800 bytes downloaded
[16:05:07] + 471040 bytes downloaded
[16:05:07] + 481280 bytes downloaded
[16:05:07] + 491520 bytes downloaded
[16:05:07] + 501760 bytes downloaded
[16:05:07] + 512000 bytes downloaded
[16:05:07] + 522240 bytes downloaded
[16:05:07] + 532480 bytes downloaded
[16:05:07] + 542720 bytes downloaded
[16:05:07] + 552960 bytes downloaded
[16:05:07] + 563200 bytes downloaded
[16:05:07] + 573440 bytes downloaded
[16:05:07] + 583680 bytes downloaded
[16:05:07] + 593920 bytes downloaded
[16:05:07] + 604160 bytes downloaded
[16:05:07] + 614400 bytes downloaded
[16:05:08] + 624640 bytes downloaded
[16:05:08] + 634880 bytes downloaded
[16:05:08] + 645120 bytes downloaded
[16:05:08] + 655360 bytes downloaded
[16:05:08] + 665600 bytes downloaded
[16:05:08] + 675840 bytes downloaded
[16:05:08] + 686080 bytes downloaded
[16:05:08] + 696320 bytes downloaded
[16:05:08] + 706560 bytes downloaded
[16:05:08] + 716800 bytes downloaded
[16:05:08] + 727040 bytes downloaded
[16:05:08] + 737280 bytes downloaded
[16:05:08] + 747520 bytes downloaded
[16:05:08] + 757760 bytes downloaded
[16:05:08] + 768000 bytes downloaded
[16:05:08] + 778240 bytes downloaded
[16:05:08] + 788480 bytes downloaded
[16:05:08] + 789667 bytes downloaded
[16:05:08] Verifying core Core_a1.fah...
[16:05:08] Signature is VALID
[16:05:08]
[16:05:08] Trying to unzip core FahCore_a1.exe
[16:05:08] Decompressed FahCore_a1.exe (2035712 bytes) successfully
[16:05:08] + Core successfully engaged
[16:05:08] Deleting current work unit & continuing...
[16:07:29] - Preparing to get new work unit...
[16:07:29] + Attempting to get work packet
[16:07:29] - Connecting to assignment server
[16:07:30] - Successful: assigned to (171.64.65.64).
[16:07:30] + News From Folding@Home: Welcome to Folding@Home
[16:07:30] Loaded queue successfully.
[16:07:31] - Error: Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[16:07:40] + Attempting to get work packet
[16:07:40] - Connecting to assignment server
[16:07:40] - Successful: assigned to (171.64.65.64).
[16:07:40] + News From Folding@Home: Welcome to Folding@Home
[16:07:40] Loaded queue successfully.
[16:08:02] + Closed connections
[16:08:07]
[16:08:07] + Processing work unit
[16:08:07] Core required: FahCore_a1.exe
[16:08:07] Core found.
[16:08:07] Working on Unit 06 [June 6 16:08:07]
[16:08:07] + Working ...
[16:08:08]
[16:08:08] *------------------------------*
[16:08:08] Folding@Home Gromacs SMP Core
[16:08:08] Version 1.74 (March 10, 2007)
[16:08:08]
[16:08:08] Preparing to commence simulation
[16:08:08] - Ensuring status. Please wait.
[16:08:25] - Assembly optimizations manually forced on.
[16:08:25] - Not checking prior termination.
[16:08:42] - Expanded 4677502 -> 24111057 (decompressed 515.4 percent)
[16:08:43] - Starting from initial work packet
[16:08:43]
[16:08:43] Project: 2665 (Run 1, Clone 456, Gen 8)
[16:08:43]
[16:08:44] Assembly optimizations on if available.
[16:08:44] Entering M.D.
[16:08:50] Rejecting checkpoint
[16:08:52] Protein: IBX in water
[16:08:52] Writing local files
[16:08:59] Extra SSE boost OK.
[16:08:59] Writing local files
[16:08:59] Completed 0 out of 250000 steps (0 percent)
[16:25:04] Writing local files
[16:25:04] Completed 2500 out of 250000 steps (1 percent)
[16:36:01] Service stop request received.
Folding@Home Client Shutdown.
