New EK Water Block ITX case.
Basically bigger than the caselabs s3, which is a large case for itx standards. Not really fond of the design.
If they dropped one of the 120's up front and narrowed the case by an inch or so it might be a cool product but its just too big for me to care about it too much. I mean I'm sure the build quality will be great but its kind of huge...
EK ITXat 17.25" x 7.75" x 18.5" = 2473 Cubic Inches...
Lian Li A05B 8.26'' x 15'' x 19.3'' = 2391 Cubic Inches...
Why is this thing bigger than an A05B?...
I rather like it based on the looks and craftsmanship alone. But I also agree - too big for a small case, and too small for a large one...
The curved window is cool, but I have to question what purpose it serves. The article mentions showing off your gpu, but is the back of a gpu really that pretty?
Not the back of the GPU. Since it's a reverse motherboard orientation, you'd see the EK waterblock, presumably the acrylic version with the coolant showing.
I'd buy it. But for a w/c company, why not build radiators into the case itself and just leave some g1/4 holes to tap in. Its clear that's what it was made for, but if the pipes ran through the tower itself they could save space and make it more effective I would think.
+1 for this!
When I read the title I jumped a bit because I thought they might be building a case with the radiators integrated into the frame. Looking through the pictures it is sharp, but all the components are so far apart.
It's a pass for me.
Because water coolers want a choice of radiator, and a choice of orientation. Depending on size, thickness, performance, budget, customer choices vary wildly. It needs to be removable for flushing, cleaning.
And if you build the radiator into the frame, you might prevent mounting fans as the customer desires.
That is true in general but considering this is EK's own case, with only one possible radiator mounting surface and their limited radiator lineup, it would not be such a weird idea. But EK just wants to sell another product that compliments their other products, not "replace" another product. Now you get to buy a case + radiator, whereas an expensive case with radiator would probably not be received very well.
I think this is way too big for an itx case. I know it's dictated by the size of the 360 rad, but is that really neccesary?
I do however think the general idea of starting with a radiator, and designing the entire case around it is intriguing. Though this is huge, that philosophy could probably be applied with success on SFF type cases.
Not really feeling the curbed window, but that's a purely subjective thing.
It is big, very big in fact... but the design is extremely, extremely nice.
I'd buy if I wanted a high-end mITX watercooled system, no doubt.
I think 2 slot mITX cases are pointless, many are around the same size as mATX cases. I know I ran this into the ground on many forums, but a Element Q size case, .05 taller so GPUs will fit & 2 slot so you don't have to look for a single slot. I found like 2 cases like that in Europe, but why not here?
2 slot mitx pointless? really?
because finding a single slot gpu worth your time is pretty hard now. I have a single slot case now and am stuck with an ati 5770.
