Does this look like a good pump ? it has 1000l/h flow. It's rather cheap aswell.
Check the description and give me your input
Article Description:
EHEIM compact 1000 is the new pump for use under water. The pump is suitable for use in aquariums, keeping and rearing tanks where reliable water conveyance, circulation or flow is required. The flow rate can be adjusted by the slidable output regulator as required. Thanks to the small dimensions the immersion pumps can be installed in the smallest of spaces. The pump can easily attached by suction holders to the inside panel of the tank.
Technical Data:
Pump output: 150 - 1000 l/h
delivery head: 2,0 m
Power consumption: 23 W
hose cennection pressure side: 16/22 mm
Dimensions length: 78 mm, width: 54 mm, height: 94 mm
Technical Data:
