New DVD drive problem
nwahs000
Hello-
A friend of mine bought a new dvd burner to replace his DVD-ROM, that was having trouble reading discs. He took the old drive out and installed the new drive and now the computer won't turn on at all? He's tried to plug it in to a different socket but no luck. In fact he know's it's getting power because there is a little light on the motherboard that is on when he plugs it in. Any ideas? Any help is appreciated? Thanks.
Try a complete power flush.
Pull power cord from power supply.
Hold power button in for 20 seconds.
Plug PC back in, and turn on.
Has he tried unplugging it again to see if it still works?
Is it PATA? Is the IDE cable installed with the red strip toward the power cable?
Maybe you knocked something loose? Try resetting any connections.
He unplugged the ide cable from the MB and tried to boot it up but no luck.
We tried the flush but nothing with doing that.
Only other thing I can think of is to check the power button switch, - make sure it hasnt come disconnected from the motherboard.
