New Drive?
Fritzz
So just had what I think is a disk failure on my WHSv1 server. Wanted me to make sure the disk was connected, said it was missing. I pulled the drive and hooked it to my main PC. From what I remember I should be seeing files on there right? I can view the HDD and it shows up in My Computer. It shows there is 63.5GB free out of 1TB, but I don't see anything. No folders no nothing. Is it reasonable to expect it's toast and I need to order a new drive?
Thanks
Look at the SMART info on the drive to determine that. In windows a program like CrystalDiskInfo will tell you if the drive thinks its bad.
