new drive
boucher91
am getting a new drive (sata) prolly max10 orsegate barricuda..
what is the best way to install the new drive as primary os drive, easiest safest way too get windows c: drive to the new c:drive,, cloning ,imaging????
hopefully free and without having to reinstall windows..
tia
My suggestion (and you won't like it) : Do a fresh install of Windows. Why? You'll spend more time messing around with ghosting/cloning programs than you will doing an install of Windows and all the games, that is, if you're not familiar with them. I've heard that Acronis makes a good disk cloning program.
