New drive size problem
Discussion in 'SSDs & Data Storage' started by tarxsix, Nov 23, 2019.
  1. tarxsix
    tarxsix n00b
    23
    Dec 18, 2010
    Hi, I got a 4GB WD HDD and was initializing it (GPT) when the USB connection cut. It was showing the correct size before but now shows less then half. Is there a way to fix this? I've done the Googling and tried switching to MBR then back to GPT but no luck.
    Regards,
    Tar
  2. Comixbooks
    Comixbooks Ignore Me
    14,083
    Jun 7, 2008
    Right click the Start button and check out disk management. Doh I didn't know what GPT stood for not really sure you could just delete everything and start over if it's not your main drive.
  3. tarxsix
    tarxsix n00b
    23
    Dec 18, 2010
    Welp, I requested a replacement. Could not find a fix.
  4. Master_shake_
    Master_shake_ [H]ardForum Junkie
    9,987
    Apr 9, 2012
    how old is your pc?
    you must mean tb right?
    also you should have used diskpart and deleted the partition.
    basically
    list disk
    select disk x whatever number
    clean.
    that's all folks.
