new dell computer at work....500G drive
sparks
Yes I know the conversion of space and formatted space but this doesn't make any since.
The c partition is 150gb and the logical (d) partition is 232 gb.
that is 382G of formatted space. Where is the rest of the drive?
Drive manager does not show anything.
Can you post a screen cap of drive manager? A 500GB drive should show up as ~465GiB. So you're missing about 80GB.
80 GB sounds a bit extensive for a recovery partition. And this should be visible in disk manager.
You can set recovery partition size with the dell OEM installer disk, it was set to 80GB most likely as others suggest. You should be able to see this in the boot utils dell provides.
You should still be able to see the recovery partition in Drive Manager even if it's not assigned a letter.
