I jist received my new heatsink: xigmatek loki sd963. Im just confused which directipn the fan needs to face the actual heatsink. Does the fan blow into the heatsink or does the fan blow away from the heatsink?
The instructions are horrible, and from looking at the drawn pictures it looks like i mount the fan so it blows away from the metal heatsink.
Im on my phone and its hard to google an amswer
Thanks
**note: i dont have a case. My motherboard sits on a second table in a cold room o havent used a case in years.
***edit 2** see pics below, as i have fan installed. "back" of fan is to heatsink, "front" of fan is facing away.
i used speedfan to check my temps and they are as follows:
temp1: 36c
temp2: 39c
temp3: 25c
core 0: 35c
core1: 34c
gpu: 41c
are these about right? no overclocking here.
pics
Thanks
temp1: 36c
temp2: 39c
temp3: 25c
core 0: 35c
core1: 34c
gpu: 41c
pics
