WozniakMac
- Sep 3, 2005
http://www.newegg.com/Product/Produ...037998&IsNodeId=1&name=80 PLUS GOLD Certified
Have fun. Ordered the AX1200.
I just picked up the Corsair 1000watt PSU - had the 1200 been there for purchase via Amazon I probably would have jumped on it...but honestly I think even the 1Kw is overkill for my rig
I want a decent modular, but I'll pass with it at $175.
A little expensive, if they beat the seasonic x series it might be worth it.
$199 for an 850W? I'd just get an xfx 850W at that point, seasonic built as well although only 80plus silver.
If you're in the market for the best, I would not hesitate to select Corsair.
While I do have to agree that Corsair has good customer service and decent PSUs, they originally weren't the best.
Not to mention their GS series are mediocre at best.
The xfx ones are like $140 as well, plus modular and whatnot. TX950 is a good unit as well though.Why even spend that on a 850w unit?
Just buy a Corsair TX950 for ~$140 and be done with it... Great unit.
Of course, M12D is still an excellent platform.Well, the AX750/850 are Seasonic X based, and the XFX is an M12D. There is naturally going to be a price difference.
Guys quick question, my current ps is a Ultra X connect 750watt and on its last leg. I installed a 3rd HD the other day and now i get this real high pitched sound. Already swapped PS with my bother and confirmed that's the problem.
Im looking to upgrade but not sure how many watts will suite my needs. My set-up right now is a AMD 6000, 2 gigs of ram, 3 HD, DVD D, 4 fans, 8800gt, sound card. Im going to upgrade to a Intel i7 930, 2 more gigs of ram and upgrade video cards to a 5850. Im stuck on modular PS have had one for the past 5 years. Looking at getting a Corsair, will the 650hx be sufficient enough or 750hx watt?
Would appreciate some input as iv been outta the whole PS loop for a while now.
Thanks for the reply Ramon!! Just curious how does one go about actually knowing how much power a rig needs?
I just ordered the AX850, I just hope it doesn't have coil whine from the graphics card. I had a corsair PSU 2 years ago that would coil whine when ever nvidia card hit high fps. I returned it after 1 RMA with the same issue.
I want to finish my new build and didn't feel like waiting god knows how long for the seasonic X-850.
the ax850 and seasonic x850 are the exact same psu..
CX PSUs are budget models so they don't have as lengthy warranties as the higher-end models.Why does the CX430 only have 2 years warranty? I though all corsairs came with 5?
Still the new models look great, if this one ever break i'm surely going back to corsair
Honestly I believe it's an evolution of the X-series but I don't know that for a fact, so I'll double-check with our engineers.
any particular reason the 750 & 850 are Seasonic based and the 1200 is Flextronics based?
great news, fully modular FW. the AX850 is my next PSU. any [H] review on the way?
Search and you will find: http://www.hardocp.com/article/2010/07/13/corsair_ax1200_1200w_power_supply_review/
