New Core 2 Duo wont POST
Scolecite
I have a Rosewill 550w pwr supply, the smaller 4 pin connector goes by the bigger power connector right? Not across the mobo like a P4 connects.
I installed the cpu and 2 sticks of Muskin 6400 DDR
On a Gigabyte 965p-DS3.
And a 7600 GT PCI express.
This is ALL I have attached to the board right now. Even if I take the RAM out the same thing happens, NOTHING. The fans all start (the CPU fan takes a second to get gonig) and thats it.
Any suggestions?
EDIT: PROBLEM SOLVED there was a 2x8 looking thing that was in fact the 2x4 I needed for the P4 connector on the mobo.
THank you guys so much for the quick responses.
allo have you checked your jumpers on the mobo using your mobo manual of course make sure there all set right iv had a mobo come from factory with jumpers set wrong....
I dont have any jumpers on the board. I just put a jumper on cmos reset and that was about it. :mad:
There is no cluster of jumpers to set. When I take the battery out and start it it does the same thing as when I take the both rams out. Nothing. I put cmos in and ram back in, same thing nothing, just all fans active with no monitor power up and no beeping or post.
uh oh...
you should have a 2x2 that plugs into an independent plug like on p4's. Then you should have a 20pin with a 2x2 that can attach next to it. For some stupid reason, they've made the keys the same on both 2x2's and a lot of people have been switching the two by mistake recently. It's no good. Results in usually blown equipment since the pinouts for the two 2x2's aren't the same
uh oh...
I don't have (2) 2x2's just ONE and it dosent have that little clip on it to attach to what I call the P4 connector spot on the mobo. I have a 2x6???
OH YOU MOTHER %#^$%#^($*$&
I just seperated the 2x8
THANK YOUGUYS SOOOO MUCH FOR THE HELP. I REALLY MEANS ALOT TO SOMEONE OUT THERE.
I'd return that PSU, lol. If you read the recommendations at the psu subforum, you'll find out why.
