Jul 30, 2007 #1 T TSGrayson Limp Gawd Joined Sep 9, 2004 Messages 139 I am currently running a WC setup on my QX6700 and 2xGTX in SLI...what temps should I be seeing?
Jul 30, 2007 #2 B bail_w Supreme [H]ardness 2FA Joined Oct 21, 2005 Messages 4,240 it depends on your Vcore and ambient temperature.
Jul 30, 2007 #3 T TSGrayson Limp Gawd Joined Sep 9, 2004 Messages 139 I am running Vcore at 1.3 and have it OC to 3.2...
Jul 31, 2007 #5 B bail_w Supreme [H]ardness 2FA Joined Oct 21, 2005 Messages 4,240 can you list your watercooling spec?
Jul 31, 2007 #6 R rincewind Gawd Joined Sep 21, 2004 Messages 888 Impossible to say without adequate information. Like what blocks are in the loop, the pump you're using and what rad/fans are dissipating the heat.
Jul 31, 2007 #7 T TheBlank Limp Gawd Joined Nov 15, 2006 Messages 164 don't forget how hot the room is itself.
