New Computer Parts List - Advice Please
nuschu
I'm helping a friend build a new system and we worked out the following list of parts last night. I was hoping to get some advice on the parts list so far. If there are any parts that just generally suck or of there are similarly priced parts out there that outperform these, I'd like to hear about them. He mainly does gaming, web development, some minor audio stuff, and possibly some minor video type stuff:
Antec P180 Case
http://www.newegg.com/Product/Product.asp?Item=N82E16811129154
Antec TruePower 480W SLI Ready
http://www.newegg.com/Product/Product.asp?Item=N82E16817103929
AMD Athlon 64 X2 3800+
http://www.newegg.com/Product/Product.asp?Item=N82E16819103562
Abit AN8 32X ATX Motherboard
http://www.newegg.com/Product/Product.asp?Item=N82E16813127232
Patriot 2GB DDR 400 (PC 3200) RAM
http://www.newegg.com/Product/Product.asp?Item=N82E16820220040
eVGA GeForce 7900GT
http://www.newegg.com/Product/Product.asp?Item=N82E16814130281
Western Digital 74GB Raptor (system drive)
http://www.newegg.com/Product/Product.asp?Item=N82E16822144160
Maxtor DiamondMax 10 300GB (storage drive)
http://www.newegg.com/Product/Product.asp?Item=N82E16822144014
Sound Blaster X-Fi Platinum
http://www.newegg.com/Product/Product.asp?Item=N82E16829102190
Overall, looks like a good list to me. Since gaming would most likely be the most intense thing for this comp, it should be able to handle it very well (and if you need better gaming performance at a later time, slap in a second 7900GT). I'm not entirely sure about the video card though, I've been a little out of the loop about the best 7900GT.
I priced a very similar build yesterday for my friend.
If you're looking for an optical drive, look at the NEC-3550A or Benq 1650. Both can be had for under $40.
Looks good. I dont really think the x-fi platinum is really worth it for the front panel, but its just a personal preference. I would rather spend that money on a better graphics card
I think he utilizes the front panel on the XFi for some audio stuff he does so he'll probably want to keep it...
Ok, after some revisions suggested on the forums I posted this on, I came up with this list. Once again, any comments or suggestions are appreciated. Especially looking for comments on a heatsink/fan combo or a watercooling solution for the CPU, or both for the sake of comparison :) ... Mainly looking to keep this thing cool, but also as quiet as possible. I'm using an XP-120 with a quiet 120mm fan on my computer, but not sure what I should recommend to him. Here is the second draft list (I left my notes to him in there just for the hell of it)...
Case
Antec P180 Case $133.33 (cheaper at zipzoomfly after adding shipping at newegg)
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=140118
The other option is sticking with your current case (Antec P160) and moving your old system into a media center type case for BeyondTV service...
Power Supply
We might need to get a 4-pin extension cable if you want to route the cable in the P180 case, at least that is what I'm reading:
http://episteme.arstechnica.com/groupee/forums/a/tpc/f/77909585/m/545003668731/r/680009668731
Seasonic S12-500 - $119 after rebate (more expensive but more reliable, very quiet, and all the cables are wrapped)
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=271603
Antec Smartpower 500w - $66.59
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=273503
Antec TruepowerII 550w - $79.99
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=270001
Processor
AMD Athlon X2 3800 - $297
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80721-1
AMD Athlon X2 4200 ($337 when purchased with the OCZ memory below)
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80725-R
Memory
OCZ Gold GX 2GB - DDR 500 - $162.99 after rebate
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=85204
Hard Drive
Seagate 400GB SATAII - $199 (saves you $80 by getting one drive instead of 2)
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=101544
Motherboard
http://www.nforcershq.com/article5877.html (DFI better for overclocking but the A8N 32X supports x16 SLI)
Abit AN8 32X - $154.99 after rebate - expires 4/30
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=240189
Video Card
EVGA 7900GT - $319
Sound Card
Soundblaster X-Fi Platinum - $159.99
DVD Drive
NEC ND-4570A - $39.99
http://www.newegg.com/Product/Product.asp?Item=N82E16827152070
Misc
10" Rounded IDE Cable - $2.99
http://www.newegg.com/Product/Product.asp?Item=N82E16812881028
4Pin Extension Cable - $3.50 (just in case cable routing in the P180 is an issue)
http://www.newegg.com/Product/Product.asp?Item=N82E16812198005
Arctic Silver 5 Thermal Compound - $5.99
http://www.newegg.com/Product/Product.asp?Item=N82E16835100007
Heatsink & Fan (Need Recommendations)
