New computer, mulling over my cooling options
gopherscanswim
I've read through some threads here, but I'm feeling so indecisive that I need to start my own.
I have new parts on the way for a new computer and just the basics are an Asus P5B-E, Intel E6600 and the case is a Lian-Li PC-V1100BPlus II. I'm trying to decide whether I should stick with the stock hsf or replace/upgrade it when I do the initial build. Of course I plan to use AS5 regardless, but I'm out of the loop on higher end air cooling. The last thing I bought was an SP-94 almost 3 years ago.
My main interest is a quiet case, but at the same time I won't be overclocking a whole lot so I doubt I really need a ginormous tower cooler. Even better if whatever I get can be installed without clearance issues, or requiring some bolt through mounting bracket. I would also prefer something that has a reasonably good contact surface since I'm getting less interested in doing things like lapping the heatsink if I don't have to.
I've looked at the Zalmans like the 9500 and 9700, and I think both would fit in my case and as far as airflow goes they'd work well with the exhaust fan near the CPU in the back of this case. I've also noticed the Scythe Ninja might work, although I haven't got a clue how much space is actually available in this case just yet. So if anyone has that case or knows the general layout (it's similar to the PC-V1000 cases) I'd appreciate some input.
Thanks!
Tuniq Tower, Scythe Infinity, Zalman 9700
All great choices for CPU cooling, even though most are bolt-through.
The 775 mounting mechanism sucks for larger coolers... I'd never suggest a "clip in" HSF over the stock one.
But, the AC freezer 7 is clip in I do believe. It's also about 25$ anywhere but newegg.
OK, that's good info to know. I don't know a whole lot about the 775 mounting system, although I can tell it's not similar to the 478 system. The Zalmans don't seem to have any fit issues with the P5B-E.
