New Computer for a Poker Player ~$800
Computer will be used mostly for online poker playing up to 12 tables. Web browsing and watching movies as well.
Flexible budget of about $800. Could go more if I really need to. Less would be good too.
3) Where do you live?
South Florida
I'm not sure why everything isn't valid, but I need pretty much everything but the monitors. Case, cpu, ram, dvd burner, hard drive, motherboard, video card, fans, power supply. Am I missing anything here? Wiring? Edit: Just checked out a different sticky with more info. I would like a decent soundcard to go with my Sennheiser HD25-1 II headphones.
None.
6) Will you be overclocking?
I will not be overclocking unless I can be convinced I really need to.
I have two 24" monitors with max resolution of 1920x1200. I need a video card capable of handling that and maybe even 3 monitors if that's not too expensive to do.
Immediately. Hoping to take advantage of some of the Newegg Black Friday deals if possible.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
I just need standard features, unless someone can recommend something awesome I don't know about. I'd like a good amount of usb ports. Do I need USB 3.0?
Yes. 64bit Windows 7.
Looking forward to suggestions. Let me know if I missed anything. Thanks for the help!
Edit: What are the chances I have the longest registration on this site in this thread?
I'm curious if you analyze the hand histories of your opponents and if so whether that is a performance bottleneck. Is it IO or CPU limited?
I'd lean towards an SSD. $800 will buy you a lot if you don't need a high end video card and $120 or so on a 64GB SSD will buy you more perceived performance than an extra $120 on the CPU.
As a plus, simply having two drives of any kind makes it easy to set up a backup rotation for critical files. My SSD backs up diffs automatically to my hard drive.
I'd go with a 3rd screen, if possible.
This is the best advice. When I play only 3 tables and web browse with one screen I feel extremely limited. I can't imagine 6 tables per screen being all that hot while trying to juggle other activities as well.
If none of your existing displays can go into portrait mode getting such a display would be a good upgrade because the screen real estate on the poker sites I've played on is fixed and you'll maximize screen space usage by going vertical.
Since you also like to stream movies I would suggest looking into a dedicated Network interface card to improve stability. You shouldn't need to spend more than $35 on that.
