1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? Etc
I will be using it for gaming.
I have a budget of 700, maximum of 750.
3) Where do you live?
Lowell, Massachusetts
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
Case, Mobo, RAM, CPU, hard drive, video card, power supply
BenQ 16X DVD±R DVD Burner With LightScribe Black E-IDE/ATAPI Model DW1655 LightScribe Support OEM
6) Will you be overclocking?
I dont usually overclock
Ill be using a resolution between 1680x1050 to 1920x1080
Hopefully in the next couple of weeks.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Firewire, but not necessary.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Vista business 64-bit
Thank you in advance!!
