New computer build, having problems
scud133
Disclaimer: Trying to run windows on a SATA drive and this is the first one i've owned so that may have something to do with it
Struggled for a while just to get windows installed properly on the drive (this thread). It's installed now and works (trick was F6 at windows setup and used the sata RAID floppys that came with the motherboard. I'm worried about this though since I don't have a RAID array but it was the only way to get the installation to finish). BUT NOW>>Every time I reboot from windows, the systems appears to freeze after POST. There is still a signal going to my monitor, but the screen is all black, no blinking cursor. While it is frozen like this, if I hit the reset button, the computer reboots and I am prompted with the safe mode/start normally options. From here I can return to windows normally. Basically, I can never have a normal restart, I always have to be nearby to physically push the reset button after it attempts to reboot on its own. I don't even know where to begin... any ideas about what's going on??
Relevant stuff:
-BIOS and all drivers have latest updates
-MSI K8N Neo4 Platinum Ultra
-Athlon64 3000+
-WD Raptor 36gb (SATA)
-Samsung 160gb (IDE)
