New Computer Build -- Apple Power Mac g5 case
Krazy925
Hey all,
Been a while since I have wandered into this subforum as it has been quite a while since I have put together a new PC.
Thanks in advance for any suggestions/insights provided. I always respect the information that comes out of this subforum.
This computer will be my backup PC while I upgrade my main PC. It will be used for 4k gaming. Eventually I might even want to use it as a VR rig.
$250 -- I am extremely flexible on budget -- but don't rec enterprise SSDs please and I'm pretty sure I don't need a 1600w platinum rated PSU.
Concord, CA -- I live on top of Fry's essentially. No microcenter unfortunately.
I need a CPU cooler, PSU and SSD
What I already have -- motherboard (ASRock Z97 Fatal1ty Killer), CPU (4790k!), case, HDDs, RAM. I will also be purchasing a GTX 1070 most likely for this build as I can't justify a flagship GPU for a backup gaming rig.
6) Will you be overclocking?
Yes.
I have a 28" 4k but also will be getting a 34" 3440x1440 widescreen monitor.
All parts besides GPU will be bought this week. Possibly even today.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
N/A
Will most likely be using w10 for this build as I haven't had any chance to play with it.
Thanks again for any help.
