New comp, suddenly no post, no beeps, nada
Tristanic
First off I will state that I am a total noob. This was my first build and things went great for the first month or so. Then, all the sudden, I when I turnded it off it would take a few tries to get it back on. I read up on it and uploaded the newest bios. Restarted it just fine. Then turned it off and now....nothing. Hit the little power button and the fans spin like crazy but nothing past that, no beeps, no video, no shut down. just spinning fans. Any ideas what I should do here?
Bits:
Opty 165 cooled by a ninja,
ASUS A8R32-MVP Deluxe Motherboard
Raptor 74GB X2 (not raided)
Corsair XMS 2GB (2 x 1GB) Twinx2048-3200c2pt
Powercolor 1900XT512MB
Enermax Liberty ELT500AWT ATX12V 500W Power Supply
Lian Li PC-65 Silver Aluminum ATX Mid Tower Computer Case
Audigy 2zs platinum soundcard
hp light scribe dvd
XP Pro sp2
I think that is about everything I have hooked up to it.
If I have missed anything important let me know, but I really have no idea what my next step should be. I have never tried overclocking it. I have tried booting up with the asus boot cd, and clearing the cmos I think, someone on AT suggested I boot up with only mobo, cpu, gpu, one stick of memory and a HD, still a whole lotta nothing. Other than that I have no idea. HELP!
Rebuild it? Crazy stuff happens sometimes...I had a troublesome IC7 that would refuse to POST after just TOUCHING the RAM. It was lame...ahh..so many hours of rebuilds and troubleshooting. Nothing was ever broken, thing just sat there like something was. Till I took bits of it apart and put it back together. Usually a full out rebuild (motherboard and everyone on it out) fixes things. I can now assemble my computer blindfolded, upside down, and in <5 minutes.
Not too sure other than that...if it's been working, then stuff normally just doesn't poop out like that. Extra components are handy, it sounds like a PSU or motherboard issue though.
Strip it to a minimum config, just cpu, vid card, memory.
Then try booting without any memory.
Do you get the bios beeps for bad memory ?
Then try booting without the vid card.
Do you get the bios beeps for a bad vid card ?
If you get beeps then you've found the bad part.
If no beeps at all then its either/or a bad PSU, CPU. MOBO.
Without swopping parts with a working comp its hard to go further than that.
Luck........ :D
Oh..yeah...crap...forgot those... -__-
The board shouldn't been if there isn't a video card installed though, it'll POST just fine. On the other hand..memory..yes. If there isn't a stick in the slot and it beeps, it means the motherboard and processor work, but the memory isn't.
So.....I took out the HDDs, no beeps
took out both sticks of memory, no beeps
took out the videocard, no beeps
Now what?
Reset the bios using the pin connector or remove the battery for a few minutes.
He's already done that.
Build outside the case and try it?
Rebuild it altogether?
Test individual components in working rigs?
Yes I see that now. I missed it the first time I read his first post.
To Tristanic: Building out side of the case is a good idea. Try and get the system to post with the minimum amount of hardware.
Well, I am finally getting somewhere! I took it out of the case and stripped all the bits down and narrowed it down to the ram. This is where I am getting confused though. The ram I have is Corsair xms 3200pt 2GB. They are a matched set but I can't boot up with them both in my board. I have tried both separately to see if it was one of the sticks and they worked fine.
I think I have them in the right slots A1 and B1. And these are the slots I had them in before. I am using the latest BIOS so I am not sure where to go from here. Any ideas!?!?!?!?
ps, pls let me know if I left out any vital info!!
Does that mean they work in single channel, but not dual channel? Or just don't work with each period.
I am not sure, sorry, me = newb. When I have both sticks in the machine, nothing happens. When I just have one stick in (either stick seems to work) it starts up fine.
Not sure.
One of the slots might have died ?
Bios is mis-reading the timings with two sticks in ?
As a quick test, I would download and run Memtest86+.
That the best way to check the sticks out for errors.
If it comes up error free for both sticks then your memory is probably fine and it may be your mobo thats iffy.
Luck........ :D
