new CAT 6.7 question
MaxOut313
I have X1800 Crossfire setup and is actually crappy with world of warcraft. I noticed the new Windows XP 6.7 drivers force AFR. Im using Windows X64 and that version of the drivers dont have that feature. Could I use the windows XP drivers with X64 and will they work fine or i can not do that? I really could use that feature in hopes for better FPS. If not is there a way to get the X64 drivers to force the AFR feature??
Nope, why are you using Windows XP 64 anyways if you want to use crossfire and play games???? Seems like a waste of your hardware by limiting yourself with your os, why not use linux?
Uhh...huh?
It seems you're out of luck on this one, which is why I recommend that everyone set up dual- or multiple-boot configurations for XP32/X64/Vista Betas.
