new case
fightingfi
DOH ! bought a new http://www.newegg.com/Product/Product.aspx?Item=N82E16835214061
it doesnt fit in my cougar pc case though i have the 2 fans ava on top it basically blocking my ram slots and the rear is a single 120 fan. would like a case with at least 2x120 fans in the front of the case for air intake and need room for my new toy can be rear mounted or on top but like i said doesnt have the room in this case. would like to stay UNDER 50 Bucks!!!!!!!
So here is the case that it doesnt want to fit in the new cpu cooler i had purchased http://www.newegg.com/Product/Product.aspx?Item=N82E16811553003
cpu cooler here http://www.newegg.com/Product/Product.aspx?Item=N82E16835214061
Thanks for the Links for some reason all the cases seem to be *short* on the top and my motherboard like the cpu cooler wont fit in and wont lineup properly at all, then the Memory wont fit in becuase the cpu cooler is blocking the dimms on the top also. Not sure what to do from here beside return the cpu cooler and just go back to stock unless i can find another case with more than 2-3 inches of room on top for the cooler.
I returned it but its ATX im always looking so if you have any info, links plz send thanks :)
you returned the aio? that was a pretty damn good deal! so no need for a case now?
