Current Case/build:
As you can see it is pretty old and has a few poor mods done to it. Since it's probably a good time to clean out my watercooling loop I figure why not make it fun and transfer this build to a new case and make it clean.
If you know of a good case $50 or LESS, please let me know. I want something clean and not flashy.
I have this in mind:
XCLIO 188A COOLZER Mid Tower
I plan on removing the two side fans and back fan with black yate loons. I will also be permanently removing the front cover.
New plan:
I want to mount the dual radiator above the case and cut holes for the tubing to go into the case. I also plan to paint the inside of the case completely black (even though there is no window... i know). The two side fans and two radiator fans will have the foam fan grills (don't know exact name).
Please let me know what you think. Also if you have any case and/or mod suggestions please let me know!
New plan:
