new case help
fightingfi
on a laptop right now old case useless bent etc.........im looking a for case to hold a rtx nvidia 2070 its really LONG. room for LOTS of 120 mm fans to use from old case MUST have 1x120 rear fan 3 x 120 mm in the front would be nice AND i know i know its OLD but have alot of cd games to install 1 or 2 dvd bays also Tankies so Much in Advanced oh yes about 100 bucks price if Possible :D
was there something in particular you want help with? or are we your personal shoppers?
As always I recommend the Cooler Master Master Case 5 Pro. Not the one with the solid front panel, the one with the mesh.
*Edit, the original one like I have is hard to find & expensive now, here is the updated version of the same case (Without the top cover)
https://www.newegg.com/dark-metallic-grey-exterior-with-black-interior-cooler-master-mastercase-mc500-atx-mid-tower/p/N82E16811119340?item=N82E16811119340&source=region&nm_mc=knc-googleadwords-pc&cm_mmc=knc-googleadwords-pc-_-pla-_-cases+(computer+cases+-+atx+form)-_-N82E16811119340&gclid=EAIaIQobChMIh_fe4f6h5AIVgpyzCh37Vw2cEAQYASABEgJhePD_BwE&gclsrc=aw.ds
thanks for the info and link it has a 140 mm in the back I need a 120 mm rear fan for my AIO.
You can fit both 120 or 140. I currently have a 120mm fan in mine.
From specifications page:
Cooling System
Fan Options
Front: 3 x 120mm / 140mm fan (1 x 140mm fan Pre-installed)
Top: 2 x 120mm fan
Rear: 1 x 120mm / 140mm fan (1 x 140mm fan Pre-installed)
Cooling System
Fan Options
Top: 2 x 120mm fan
Thank you again Sir for all your kind Help :)
hey do you think it might be possible to put a 200 mm on top if you jerry rig it somehow? i ordered the case will be here Friday :)
According to the specifications info the case is 9.25" in width, 200mm is 7.87402" so it may be possible. You would have to dremel it though. Glad I could help you with a case. Post pictures when you get it built :)
I was thinking about using zipties on the top to hold it in a got a free 200mm Noctua fan :)
I guess you could do that too. The only problem I see is the 200mm fan circulating hot air due to the fact that the exit hole isn't big enough. I'd probably just stick with 1 or two 120mm fans.
another question is what happens if you put a video card in Vertically? Do i lose any speed performance or any drawbacks to doing it at all?
does the case come with the bracket ir do i buy that separetly and how much or cheap can i get one please Thanks again !
The case doesn't come with a vertical mounting options for the GPU. You would have to modify it & also purchase a riser cable for the PCI Express slot.
As far as performance goes, I see you have a 2070. So do I. Mounting the Video Card vertically would probably raise the temperature a few degrees because the fans are designed to push the air away, with the card being up against the glass in the vertical mounted position, it would probably trap a bit of the hot air around the GPU. Its up for debate though. I'd just stick with the traditional mounting method, but like I said you could always mod it, there is a lot of room in the case to tinker around with :)
do you have any inside pics of your case i can see :) cant find anything online with this case to get some ideas for cabling etc... thanks !
I'll try to get some to you. Its hard to find a decent hosting site now days, I don't think I have any recent pictures though.
Nothing fancy, but I think after seeing these pics. I may clean up the cables a bit. Don't go dissing my Velcro strapped Hard Drive, its got bottom mounts and works! lol.
HEY!!!!!!!!!!!!!! my video card doesnt plug in the front like yours wtf...............
did you use the hdd bay on the side for you ssd's i cant figure out how to cable mine so i put them in teh hdd bay
did you say you can put 140's on top of teh case to i got 2x120 right now.....
Its a 2070 reference (Founders) model, maybe they made different revisions. I have two SS's mounted to the back of the Motherboard Tray. I took the Hard Drive tray out completely.
Yep, you can mount 2 140's to the top (according to the specification sheet) I only have 1.
how did you mount the hdd's im confused as how to do so can you send a pic are the 140 incl fans any good , if not what are some good fans 140 to buy i dont want to spend 30 bucks on the noctua lol thanks !
