King Icewind
- Jan 17, 2008
Hi,
I've been looking to get new case to better accommodate my computer parts. Currently I have the Antec 902, which houses my watercooling tubes, pump, two video cards, two hdd, etc. As you can tell its a little cramped.
So I've been looking around at different cases to give some breathing room to my parts and I came across the HAF 932 and the HAF 942.
Dimension wise, the 942 is longer by .5in compared to the 932 but is skinnier and not as tall. However, it has two more expansion slots (9 total), and has USB 3.0. I'm not sure which would be better to fit watercooling tubes, and the likes. So if anyone has any comments on this? I'm open to other suggestions on cases as well. I was looking at the 700D, however a side panel with a window is a must! Also I'm not looking to spend more than 200 for the case.
My watercooling is a little crazy, with the pump in the hard drive/cage and my two triple radiators mounted on the right side panel with some brackets I made. The pump is unfortunately takes up a decent amount of space and pretty much completely blocks air from the fan in front of it. There literally no where for me to hide or put the extra long cables from my corsair psu. With all my wc and parts I would estimate my computer to be around 65-70 pounds, which is major pain when I move my computer around.
My possible grand scheme is to take out my pump, radiators, T-line (resorvoir), and simply have the small amount of tubing for my cpu block, and the block inside my case. I then want all the other wc components moved to a small box or case. I would have quick disconnects for the tubing on the outside, so I could more easily move my computer around and then grab my watercooling box.
I'm not sure what I would use for this. The box or case would house the triple radiators on both sides with ether mesh or holes to allow them to push out the heat. The pump would be some where in there, along with the fillport drilled into the top for ease of filling up the res. I was also thinkikng of getting a 6 port fan controller to queit things down and for looks.
The hardest problem I forsee with this is bleeding the system. I would have my little watercooling box off to the side and below the highest point. I guess I could counter this by adding another T-Line before the highest point. It will probably be ok once I do finish bleeding it, but since I will be using black tubing, its hard to see where the bubbles are.
So I guess I'm asking for recommendations and comments for two cases!
Also, yes I was thinking of just using the antec 902 for the watercooling box, however I want something a little smaller and compact.
Thanks! Hopefully there aren't too many errors in my typing. I typed this all on my Droid.
