New Card-No sound
hellcat61
I purchased an ATI Sapphire HD 3850. After installing the card and the drivers from the disk, I lost all sound on my computer. I can't seem to find anything muted in the settings. I have a Soudblaster Live! sound card, and when I run the diagnostic that comes with the card, it says everything is working. Does this happen frequently with the ATI drivers? If so, what can I do to fix the issue.
Thanks.
Thanks.
Yesterday, when I installed new 8800GT I lost my sound. (sound blaster live 5.1) Everything was fine but no sound. Then I installed again sound card driver ===> fixed
your new ATi card also has built in 5.1 sound, so it wants to force you to use that. Go into device manager you should see "unknown devices" right click on it, and select disable. Then restart and your sound should work again, if not then after doing what I just told you, reinstall the drivewr.
Happened to me on my SoundBlaster Live when I installed my Ti4200 way back when. Re-installing the sound drivers fixed it for me as well :cool:.
Thanks.
I had a interesting little problem on a new build recently. I had a random reboot (and I mean Random). I finally tracked it down to a DCOM database locked error in Event Viewer, and that led me to a conflict between my sound card and video card...Moved the sound card to the furthest PCI slot away and it seems to have fixed it now.....
I had this happen to me with my new 8800GT
What I had to do was unplug my PC, clear my bios, and temp remove the battery for 15 mins. When I reseated everything, it all worked once I had installed the drivers. I think it has to do with ACPI or whatever it's called. The compy gets confused due to all the changes.
When it happened to me, I went to Control Panel -> Sounds and Audio Devices -> Audio and clicked my card instead of the ATI HD audio. See if this works for you.
