New card made my pc slower. need some help
Spyderco
I just got a X850Xt, i upgraded from a 9600xt.
It seems that while games play better, the overall system performance in 2d modes had worsened. i mean firefox used to open instantly with the 9600xt. Now it takes 6-11 seconds. same with almost all programs.
at first i thought it may have been a driver conflict so i used driver cleaner. But it didnt help, then i reformateed windows. I get the same problem. Thogh when I put in my 9600Xt. It is fast again.
I am getting like crahes out of BF2 from desktop.
also note. This is my 2nd X850XT. same problem on both and i have tried both drivers in the 5.6 varients/
I upgraded my memeory as i though this was the problem with the 1st card. i went fri 2x256 of OCZ pc4200, Now I have OCZ pc420o in 2x512mb kit.
My system
2.4C GHz p4 overclcoked to 3.5, Asus P4C800 E- DELUXE ,OCZ PC-4200 1GB 2.5-4-4-8
550watt psu, ATI Radeon X850XT
Try without OC-ing anything. Some cards are more sencitive on bus speeds and CPU OC-ing.
And try nvidia cards :)
MD
did you use a driver cleaner to wipe out all the old drivers? how about turning off antivirus when installing?
its something other then your video card i think. i have the same card and i havent had any of the problems your talking about. hmmmmm
I just turned everything down to stock, but I am still tetsing it out.
I have reformatted. and I havent used an Anti-Virus since 1997
Its just that when I put in the 9600XT or a older nvidia geforce 2, The pc is fast in 2d modes, faster than the x850,
Even with the OC, I ren memetest for 12 hrs last night, so id take it it was fine.
Try right clicking on your Desktop. Click Properties\Settings\Advanced\TroubleShoot. Then try playing with the Hardware acceleration bar.
If that doesn't work, i dunno if this'll help, i'm not too familiar with ATI cards. I doubt this is related to the problem but it might alleviate it a bit. In the utility that came with your driver (nView's ATI counterpart, forgot the name) have you checked if there's an option for accelerating windows screens?
Spyderco said:
il look around.
hardware acceleration is at Full BTW.
Just try moving it a notch at a time and then rebooting. Maybe it's just conflicting with something. I've found turning it down to be useful when my overlay screens kept turning green and video playback kept slowing down. Maybe something similar's happening to your desktop.
MD
Md. - Not funny, and not a solution to his problem.
John Gault = He clearly says he used driver cleaner. Read his freaking post.
Program LOAD times are disk related (and partially memory related)
You may want to reinstall your chipset drivers (i875) and run a memtest.
Then I would run diagnostics on your harddrives
and
then run memtest86 again, anyway.
Your new video card could be using a memory range that is in conflict (although doubtful)
The other thing I think could be possible is that your new video card(s) are causing some sort of EMI problem or heat related problem with your memory/cabling.
And, honestly, why SHOULD he even have had to run driver cleaner?
RADEON 9600XT
REDEON X850XT
both of them use catalyst!
RADEON 9600XT
REDEON X850XT
That's what I was thinking too. Everything worked fine when I switched from a 5900xt to a 6800.
Though I could see it happening where the driver didn't recognize the card correctly, you would think a simple reboot would fix it. But he said that he reformatted and reinstalled everything so that shouldn't matter there either.
